Noise between tracks
Hi All
Have Audirvana installed on a small windows 10 pc connected via usb to a dac.
I am using Tidal as supplier in master quality.
I am using Audirvana remotes on my ipads and samsung telephone. .
If I use Tidal directly from my pc everything sounds fine. As soon as I swith to Audirvana either via remote or controlled directly from the pc, there are loud cracks between tracks. It happens when playing a playlist and also when skipping tracks.
Any ideas?
Kenneth
Hello @Kenhaw,
Audirvana 3.5.41
Sync list: 0 folders
Library database path: C:\Users\theca\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4436MB
Local Audio Engine:ASIO 2 driver version 1110
Topping USB Audio Device
Model UID:Topping USB Audio Device
Active Sample Rate: 384kHz
Topping USB Audio Device Manufacturer:
Model UID:Topping USB Audio Device UID:Topping USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device
UPnP devices found : 1
Device #0La box Fibre UID: uuid:56066f6e-6b79-4d65-648c-40c7297a08f2 Location: http://192.168.0.15:9001/6/TMRDeviceDescription.xml
Can you try to play the same files using WASAPI instead of ASIO?
Tried that yesterday, no changes.
Can you try to change the frequency of the output using the sound settings of Windows 10 while you are in WASAPI? Do you hear a noise while you change the frequency in the settings?
https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings-winpc/how-to-change-sound-control-panel-settings-in/5a70718b-7ecf-4547-a64a-22efda8da0c2
Changing output does not help and no noise while changing.
I have found out that the cracks occur every time the bitrate of the tracks change.
I didn’t noticed you activated this, can you try without it?
Tried that. Does not change anything.
Saw someone was told to upsample everything. Tried that, now upsampling all to 768 khz and no more cracks.
What does that do to quality of music?
You tell us, does it sound better or worse to you?
