Studio 2.9.6 has just begun producing the following error in the past couple of days, and I can’t get it to stop (attempted remedial measures below):
When streaming at upsampled DSD rates (I’ve tried DSD512, 256, and 128), it will play only part of a track, then skip to the next. At DSD512, it skips after ~53 seconds; at DSD128, after ~3 minutes; at DSD256, after about 1 1/2 minutes.
Changing the amount of RAM devoted to the buffer doesn’t alter this at all. It occurs on every track I have tried. It doesn’t happen when not upsampling or when directly connected.
I have tried:
- Switching the settings for raw PCM, fix for unwanted playback stops, and gapless mode.
- Uninstalling and reinstalling Audirvana.
- Uninstalling and reinstalling the remote.
- Editing audirvana-studio.ini to remove everything except the EULA line, restarting the operating system, then restarting Audirvana Studio.
- Running Studio on Windows and two different Linux operating systems (Xubuntu and ArcoLinux; I’ve also tried Arch, but ArcoLinux is based on Arch, so I don’t count that separately).
- Changing preferences in upmpdcli regarding name of the endpoint, and whether or not UPNP AV and ipv6 are used.
- Uninstalling and reinstalling mpd and upmpdcli on my UPnP endpoint.
- Two different operating systems on the UPnP endpoint (Ubuntu Server, minimal Arch Linux).
- Two different DACs.
None of these have changed the behavior, except that once in awhile Studio will refuse to play any part of a track at all.
@Antoine , is it possible my settings saved in the cloud could have a role, and if this is possible, can you delete those preferences so I can see whether re-entering them has any effect? The behavior began when I was experimenting with VPN software that presents a second network interface to Audirvana (I’ve since deleted it), and I wonder whether this caused a problem that continues because the settings were saved from that time.
It’s distressing to be without Audirvana at the moment, because I have really been loving the sound.
Debug info from one of these sessions follows:
Audirvana Studio 2.9.6
Linux 6.13.6-zen1-1-zen x86_64 (QNAP NAS Usage: getsysinfo) x86_64 with 31.3GB physical RAM
Connected account of : Jud Fink
r8brain to DSD128 with filter type B 7th order
AUTO: /mnt/MyBook/Music/Music
Sort and display order: en
Library database path: /home/jud/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1020
Listening on on port 44081
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Active method: UPnP
enp3s0
Preferred device: [UPnP] Audio-Sparky-UPnP/AV Model UID:JF Light Industries UpMPD UID:[Obscured by me.]
Selected device:Audio-Sparky-UPnP/AV
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:[Obscured by me.]
UPnP device at [Obscured by me.]/description.xml
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get::application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::application/vnd.apple.mpegurl:
http-get::application/x-mpegurl:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
2 ch DSD 8bit little endian in 8bit chunk 22579.2kHz finite length
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
Next,Previous,Play
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Audio-Sparky-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.9.3 libupnpp 0.26.8 mpd 0.24.0 uuid:[Obscured by me.] urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /[Obscured by me.]/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-[Obscured by me.]/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-[Obscured by me.]/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-ConnectionManager-1Current device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Audio-Sparky-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.9.3 libupnpp 0.26.8 mpd 0.24.0 uuid:[Obscured by me.] urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-[Obscured by me.]/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-[Obscured by me.]/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /[Obscured by me.]/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-[Obscured by me.]/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-[Obscured by me.]/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 3
Device #0: HQPlayerEmbedded:SignalystHQPlayer5
UID: [Obscured by me.]
Manufacturer: Rygel Developers
Model name: Rygel
Device #1: Audio-Sparky-UPnP/AV
Model name: UpMPD
Device #2: [LG] webOS TV OLED77C4AUA
Manufacturer: LG Electronics.
Model name: LG TV
Max. memory for audio buffers: 16008MB
Local Audio Engine: Linux ALSA library 1.2.13
Advanced Linux Sound Architecture Driver Version k6.13.6-zen1-1-zen.
Local devices found : 7
Device #0: HDA Intel PCH - ALC1220 Analog
Manufacturer:
Model UID: HDA Intel PCH - ALC1220 Analog
UID: HDA Intel PCH at 0x2ffff20000 irq 198 - ALC1220 Analog
Model name: HDA Intel PCH
Device #1: HDA Intel PCH - ALC1220 Digital
Manufacturer:
Model UID: HDA Intel PCH - ALC1220 Digital
UID: HDA Intel PCH at 0x2ffff20000 irq 198 - ALC1220 Digital
Device #2: HDA NVidia - HDMI 0
Manufacturer:
Model UID: HDA NVidia - HDMI 0
UID: HDA NVidia at 0xdf080000 irq 17 - HDMI 0
Model name: HDA NVidia
Device #3: HDA NVidia - HDMI 1
Manufacturer:
Model UID: HDA NVidia - HDMI 1
UID: HDA NVidia at 0xdf080000 irq 17 - HDMI 1
Device #4: HDA NVidia - HDMI 2
Manufacturer:
Model UID: HDA NVidia - HDMI 2
UID: HDA NVidia at 0xdf080000 irq 17 - HDMI 2
Device #5: HDA NVidia - HDMI 3
Manufacturer:
Model UID: HDA NVidia - HDMI 3
UID: HDA NVidia at 0xdf080000 irq 17 - HDMI 3
Device #6: Pre Box S2 Digital
Manufacturer:
Model UID: Pre Box S2 Digital
UID: Pro-Ject Pre Box S2 Digital at usb-0000:00:14.0-4, high speed
USB Vendor ID: 0x2772
USB Product ID: 0x0230
Model name: Pre Box S2 Digital
Chromecast devices found : 3
Device #0: Office speaker
ID: {Obscured by me]
Model name: Google Home Mini
Device #1: Master Bedroom Display
ID: [Obscured by me]
Model name: Google Nest Hub
Model name: OLED77C4AUA.DUSQLJR
