Origin and Sequoia 15.1
I would like to upgrade macOS to Sequoia 15.1. Here’s my current config:
Audirvana Origin 2.5.17 (20517)
macOS 14.7.1 ARM64 with 16GB physical RAM
Does Origin work well on Sequoia 15.1? Are there Origin-related reasons why I should not upgrade?
Thanks.
I suggest to stay on Sonoma,
till at least 15.2 or .3
Origin works, Sequoia is buggy
It works fine for me on a MacBook Air M1 16GB/1TB streaming to a Wiim Pro. Your mileage may vary depending on your usage.
Works without problems with music on the local SSD.
All works fine for me too, using a dedicated USB connection between MacMini and amp :blush:
I have upgraded from Sonoma 14.7.1 to Sequoia 15.1 without any issues so far. My entire stack of audio apps works fine, Thanks to everyone who replied.
