If i listen to a radio station and prsss “pause” butoon when I resume the playback continue from that moment. I don’t know how much can wait, maybe depends on RAM/buffer setting? Anyway, I like this. In this way listened yesterday to the entire radio show even if dissapeared from the room for 15 minutes.
Yes, thanks for the info! Quite an interesting feature indeed! I would be curious as well to know what is the max duration of this.
Did you try to listen till the end of the show, just to know if after having emptied the buffer, the flow restart to real-time? In that case, you will certainly have a gap somewhere…
Yes, I listened till the end. No gaps. I remember last year when tried the same was a gap after 30 minutes / the show was paused from one hour. But that time I had a very low buffer (1 gb or something?). So maybe depends on buffer. Or the things has been changed since last year. The stream was aac, 48 khz, 192 kbps. Sometimes is 224 kbps.
