Bonjour
Je stream ma musique à partir d’un NAS ou de qobuz. Tout est en réseau, mac, nas, dac.
Disposant des deux versions (3.5 et studio),il m’est impossible de régler Audirvana studio pour un lecture en HR alors que 3.5 fonctionne correctement.
voici ma config:
Audirvana Studio 2.0.0 (20000)
macOS 10.13.6 with 16GB physical RAM
Connected account of : Jean-Yves FERRAND
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by album
SW volume control: ON
AUTO: /Volumes/music/
Library database path: /Users/claireferrand/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 63251
Active method: UPnP
Preferred device: [UPnP] ATOLL ELECTRONIQUE ATOLL STREAMER Model UID:ATOLL ELECTRONIQUE ATOLL STREAMER UID:uuid:5F9EC1B3-FF59-19BB-8530-0011F6A9410E
Selected device:ATOLL STREAMER
Manufacturer: ATOLL ELECTRONIQUE
Model name: ATOLL STREAMER
Model UID: ATOLL ELECTRONIQUE ATOLL STREAMER
UID: uuid:5F9EC1B3-FF59-19BB-8530-0011F6A9410E
UPnP device at http://192.168.0.38:8080/description.xml
ID 0x0
5 available sample rates up to 192000Hz
Volume control: Yes
UPnP set capabilities
Maximum PCM frequency set: 384000Hz
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get:*:audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=96000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=96000;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=88200;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=88200;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=192000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l16;rate=192000;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=44100;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=44100;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=48000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=48000;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=96000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=96000;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=88200;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=88200;channels=2:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=192000;channels=1:dlna.org_pn=lpcm
http-get:*:audio/l24;rate=192000;channels=2:dlna.org_pn=lpcm
http-get::audio/x-mpeg:
http-get::audio/mpeg:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::audio/scpls:
http-get::audio/ms-wma:
http-get::audio/x-ms-wma:
http-get::application/octet-stream:
http-get::audio/x-ms-asf:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
5 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz
0 physical formats
NrTracks: 0
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.0.26:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play,Next,Previous
<?xml version="1.0"?>1
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
<pnpx:X_compatibleId xmlns:pnpx=“http://schemas.microsoft.com/windows/pnpx/2005/11”>MS_DigitalMediaDeviceClass_DMR_V001</pnpx:X_compatibleId>
<pnpx:X_deviceCategory xmlns:pnpx=“http://schemas.microsoft.com/windows/pnpx/2005/11”>Multimedia.DMR</pnpx:X_deviceCategory>
<pnpx:X_hardwareId xmlns:pnpx=“http://schemas.microsoft.com/windows/pnpx/2005/11”>BridgecoCE2DM870_0xBD</pnpx:X_hardwareId>
ATOLL STREAMER
ATOLL ELECTRONIQUE
http://www.atoll-electronique.com/
High End Streaming Client
ATOLL STREAMER
1.0
0011F6A9410E
123810928305556upc
image/jpeg
48
48
24
/BCO_device_sm_icon.jpg
image/jpeg
120
120
24
/BCO_device_lrg_icon.jpg
image/png
48
48
24
/BCO_device_sm_icon.png
image/png
120
120
24
/BCO_device_lrg_icon.png
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1
urn:schemas-dm-holdings-com:serviceId:X_HtmlPage
/HtmlPageHandler/desc.xml
/HtmlPageHandler/ctrl
/HtmlPageHandler/evt
urn:schemas-dm-holdings-com:service:X_WholeHomeAudio:1
urn:schemas-dm-holdings-com:serviceId:X_WholeHomeAudio:1
/WholeHomeAudio/desc.xml
/WholeHomeAudio/ctrl
/WholeHomeAudio/evt
0
ATOLL STREAMER
ATOLL ELECTRONIQUE
ATOLL STREAMER
1.0
0011F6A9410E
123810928305556upc
image/jpeg
48
48
24
image/jpeg
120
120
24
image/png
48
48
24
image/png
120
120
24
/AVTransport/ctrl
/AVTransport/evt
/WholeHomeAudio/evt
UPnP devices found : 1
Device #0: ID 0x0 : ATOLL STREAMER
Max. memory for audio buffers: 10114MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Device #0: ID 0x2f Sortie intégrée
Model UID: AppleHDA:13
UID: AppleHDAEngineOutput:8,0,1,1:0
Model name: Apple Inc. Sortie intégrée
