About every 20 or 30 albums, I run into a Permissions error. Origin generates the following message: “1 tracks have not been updated, probably due to a write permission issue”. What is causing this error and how do I fix it?
Hi @thxdave,
Here you go:
Audirvana Origin 2.5.19 (20520)
macOS 12.7.6 x86_64 with 64GB physical RAM
Connected account of : Dave Morrison
AUTO: /Volumes/Public/Shared Music
Sort and display order: en_US
Library database path: /Users/davemorrison/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49236
Font size: large
Library
My Music
Startup view: Library: Tracks
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 16300MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
[UPnP] Daves CXN
Model UID:Cambridge Audio CXNv2
UID:uuid:60d33fed-27bb-4239-bf67-53a841e60916
Active Sample Rate: 192kHz
Selected device:Schiit Modi 3+
Manufacturer: Schiit Audio
Model name: Schiit Audio Schiit Modi 3+
Model UID: Schiit Modi 3+:30BE:1014
UID: AppleUSBAudioEngine:Schiit Audio:Schiit Modi 3+:100000:1
USB Vendor ID: 0x30be
USB Product ID: 0x1014
ID 0x36
Stream ID 0x37 2 channels starting at 1
24 virtual formats:
36 physical formats
Local devices found : 4
Device #0: ID 0x47 Built-in Output
Model UID: AppleHDA:120
Device #1: ID 0x3b OWC Thunderbolt 3 Audio Device
Manufacturer: Other World Computing
Model UID: OWC Thunderbolt 3 Audio Device:1E91:4001
UID: AppleUSBAudioEngine:Other World Computing:OWC Thunderbolt 3 Audio Device:2400000:1
USB Vendor ID: 0x1e91
USB Product ID: 0x4001
Model name: Other World Computing OWC Thunderbolt 3 Audio Device
Device #2: ID 0x36 Schiit Modi 3+
Device #3: ID 0x2c Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Ethernet 1
UPnP devices found : 1
Device #0: ID 0x0 : Marantz NR1710
UID: uuid:2e646ca3-9bcf-177f-0080-0005cd87ea9f
Location: http://192.168.1.79:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz NR1710
Is this is a folder from a different Mac?
No. My two Macs share the same NAS drive.
Intriguing, can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send me the audirvana_origin.log file you can find by clicking the 'Open Log Folder’ button at [email protected]
This is odd. When I copied the “audirvana_origin.log” file and tried to paste it into this reply, I got this:
please send it at [email protected]
Already done. Happy Holidays Antoine!
