Hi,
I own two network drives Pioneer N-30AE and N-50AE.
None of them are seen by A + in UpNP while on the same Mac Mini they are seen in Airplay.
Do you have an idea ?
Cordially.
Bonjour,
Je possède deux lecteurs réseau Pioneer N-30AE et N-50AE.
Aucun d’eux n’est vu par A+ en UpNP alors que sur le même Mac Mini ils sont vus en Airplay.
Avez vous une idée ?
Cordialement.
Hello,
These two network players are compatible with Audirvana Plus in UPnP mode.
But you may need to switch them in UPnP mode, and not Airplay. You can press the “Network server” key on their remote control for this.
Also, do you have any other UPnP application running on your Mac? Only one can control UPnP at a time.
Do you have more than one network interface active on your Mac?
