Playback is skipping in Tidal. There does not seem to be a pattern. Here’s the debug:
macOS 11.3.0 with 8192MB RAM
Registered to dennis wygmans
No plugin active
AUTO: /Volumes/OWC Envoy Pro EX/Music
iTunes/Music library synchronization: last synchronized on Sun Oct 25 17:06:03 2020
Library database path: /Users/denniswygmans/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2098MB
CA CXA81 2.0
Model UID:CA CXA81 2.0:22E8:CA02
UID:AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
Hog Mode is on
ID 0x67 CA CXA81 2.0 Manufacturer:CA
Model UID:CA CXA81 2.0:22E8:CA02 UID:AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
9 available sample rates up to 705600Hz
Stream ID 0x68 2 channels starting at 1
27 virtual formats:
36 physical formats
Local devices found : 3
Device #0: ID 0x67 CA CXA81 2.0 Manufacturer: CA Model UID: CA CXA81 2.0:22E8:CA02 UID: AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
Device #1: ID 0x2c CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:1200000:1
Device #2: ID 0x5b MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 Family Room UID: uuid:9ab0c000-f668-11de-9976-44fe3b6ced40 Location: http://192.168.1.29:49154/MediaRenderer/desc.xml
Thanks,
Dennis
