Hi al,
I’ve just upgraded my setup with a SoTM SMS-200 Neo network bridge. Since installing, playback regularly stops 3 seconds before the end of the track. Quite annoying. Stoping and starting again let’s tracks play again, sometimes the same tracks until the end. So I’m a bit baffled. Can anyone see what’s wrong?
Kind regards in advance
Erwin
Debug info:
macOS 10.13.6 with 8192MB RAM
Registered to Erwin Bromlewe
SoX with 2x upsampling
Bandwidth at 0dB = 95
Phase = 0
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/Extern/Muziek
AUTO: /Volumes/Extern/Onedrive Erwin/OneDrive - Windesheim Office365/De Grote Steen
Library database path: /Users/Erwin/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: sMS-200-USB Model UID:JF Light Industries sMS-200-USB UID:uuid:49fa9abc-6b70-7daf-7390-02cc06c3152b
Currently playing to UPnP device at 24 bits 88.2kHz
UPnP device at http://192.168.1.132:49152/uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/description.xml
ID 0x0 sMS-200-USB Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:02:27
CurrentURI: http://192.168.1.103:49152/audirvana/audio_0_156.wav
CurrentURIMetadata:
dc:titleScooby Doo Pa Pa (DJ Kass Official 2018 Mix)</dc:title>
dc:creatorDJ Kass</dc:creator>
upnp:artistDJ Kass</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/e9bfb58b/a764/4d9c/85b0/3aa388f9816b/640x640.jpg</upnp:albumArtURI>
upnp:albumScooby Doo Pa Pa (DJ Kass Official 2018 Mix)</upnp:album>
nextURI: http://192.168.1.103:49152/audirvana/audio_1_157.wav
Me Gustas Tu
Manu Chao
Manu Chao
http://resources.tidal.com/images/3b2a7625/f1cc/41d8/b3f9/897cacc911b0/640x640.jpg
Próxima Estación: Esperanza
6
object.item.audioItem.musicTrack
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 sMS-200-USB JF Light Industries https://opensourceprojects.eu/u/medoc/profile/ UPnP front-end to MPD UpMPD 42 https://opensourceprojects.eu/p/upmpdcli/code/ upmpdcli version 1.4.5 libupnpp 0.17.2 image/png 64 64 32 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/icon.png /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/presentation.html uuid:49fa9abc-6b70-7daf-7390-02cc06c3152b urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Info-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Info-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Time-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Time-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Volume-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Volume-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Playlist-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Radio-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Radio-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Receiver:1 urn:av-openhome-org:serviceId:Receiver /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Receiver-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Receiver-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Receiver-1 urn:av-openhome-org:service:Product:1 urn:av-openhome-org:serviceId:Product /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/urn-av-openhome-org-service-Product-1.xml /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/ctl-urn-av-openhome-org-service-Product-1 /uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/evt-urn-av-openhome-org-service-Product-1UPnP devices found : 1
Device #0: ID 0x0 sMS-200-USB UID: uuid:49fa9abc-6b70-7daf-7390-02cc06c3152b Location: http://192.168.1.132:49152/uuid-49fa9abc-6b70-7daf-7390-02cc06c3152b/description.xml
Max. memory for audio buffers: 4018MB
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x44 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-7001-01010101}
