Playback stops after two tracks, artwork and progress of first track not updated
Playback stops after two tracks, artwork and progress of first track not updated.
Windows; AS version 2.9.5; UPnP connected to Lyngdorf TDAI 1120
Please see error log below. Although initially it says “can’t find the device Lyngdorf TDAI-1120”, it does play the first two tracks (without updating artwork and progress bar after first track finishes).
I regularly find this message in the error logs “UPnP device tells but does not support raw PCM streams”, so I tried with following settings, to no avail
Error log:
2025-01-08 11:16:52.625 [info]: ============= Started Logging, Audirvana Studio 2.9.5 (20905) Windows x86_64 =============
2025-01-08 11:16:52.689 [info]: Running on Windows 11 (26100)
2025-01-08 11:16:53.950 [info]: RemoteServer: Server started and advertised on port 53039
2025-01-08 11:16:53.977 [info]: UPnP stack initialized using default interface
2025-01-08 11:16:54.204 [info]: UPnP web server started on 192.168.0.156:49152
2025-01-08 11:16:54.731 [error]: UPnP select device: can’t find the device Lyngdorf TDAI-1120 with UID: uuid:abde4097-5b06-480c-b1a8-845ac0ca98af
2025-01-08 11:16:55.514 [error]: UPnP Error 714 setting AVTransportURI to http://192.168.0.156:49152/audirvana/audioTest.pcm on instance 0
2025-01-08 11:16:55.515 [info]: UPnP device tells but does not support raw PCM streams
2025-01-08 11:16:55.537 [error]: UPnP Error 401 getting audio dB volume
2025-01-08 11:16:55.575 [error]: UPnP Error 714 setting AVTransportURI to http://192.168.0.156:49152/audirvana/audioTest.pcm on instance 0
2025-01-08 11:16:55.575 [info]: UPnP device tells but does not support raw PCM streams
2025-01-08 11:16:55.600 [error]: UPnP Error 714 setting AVTransportURI to http://192.168.0.156:49152/audirvana/audioTest.pcm on instance 0
2025-01-08 11:16:55.601 [info]: UPnP device tells but does not support raw PCM streams
2025-01-08 11:16:55.624 [error]: UPnP Error 714 setting AVTransportURI to http://192.168.0.156:49152/audirvana/audioTest.pcm on instance 0
2025-01-08 11:16:55.624 [info]: UPnP device tells but does not support raw PCM streams
2025-01-08 11:17:24.252 [error]: UPnP Error 714 setting AVTransportURI to http://192.168.0.156:49152/audirvana/audioTest.pcm on instance 0
2025-01-08 11:17:24.252 [info]: UPnP device tells but does not support raw PCM streams
2025-01-08 11:18:23.185 [warning]: UPnP GetCurrentTransportActions error => setting default actions
So folks can help the best possible, please paste your entire debug information report here… It is found here: Settings → My Account → Help → Debug info
Also please describe your UPnP network strategy/configuration.
Thank you for your reply and your support!
Due to limited technical knowledge I’m afraid I cannot describe my UPnP strategy/configuration in a meaningful way. It’s a Windows 11 PC connected via LAN to a Lyngdorf TDA-1120. Please feel free to ask more questions if necessary and I will try to reply.
Here is te Debug Info:
Windows 11 (26100) x86_64 with 16GB physical RAM
Connected account of : ano nominus
Available network interfaces:
Ethernet ({33a8495b-f4a9-432f-a1c6-6353b86ed1fa}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Bitdefender Firewall
Sync list: 1284 folders
[…for brevity sake list of 1284 folders removed…]
Tracks with no MBID: 21401
Listening on 2a02:1810:280c:4800:e202:fc6c:f0f7:3ce4 on port 55195
Font size: regular
My Music
Streaming
Radios
Podcasts
Startup view: Last displayed view
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Ethernet
Preferred device: [UPnP] TDAI-11200897 Model UID:Lyngdorf TDAI-1120 UID:uuid:abde4097-5b06-480c-b1a8-845ac0ca98af
Selected device:Lyngdorf TDAI-1120
Manufacturer: Lyngdorf
Model name: TDAI-1120
Model UID: Lyngdorf TDAI-1120
UPnP device at http://192.168.0.227:36947/abde4097-5b06-480c-b1a8-845ac0ca98af.xml
Volume control: Yes
Not automatically detected, user set to MQA Decoder
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: Yes
Unwanted playback stop workaround: Yes
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
:audio/mpeg:DLNA.ORG_PN=MP3
http-get::audio/flac:
http-get::audio/x-aac:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/vorbis:
http-get::application/ogg:
http-get::audio/ogg:
http-get::audio/x-aiff:
http-get::audio/l16;rate=48000;channels=2:
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/aiff:
http-get::text/xml:
http-get::audio/mp4:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/x-flac:
http-get::audio/x-wav:
http-get::audio/x-m4a:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/mpeg:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::text/xml:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/3gpp:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: 0:04:32
CurrentURI: http://192.168.0.156:49152/audirvana/audio_f_60.wav
CurrentURIMetadata:
dc:titleDedication</dc:title>
dc:creatorNoora Noor</dc:creator>
upnp:artistNoora Noor</upnp:artist>
<upnp:author role=“Composer”>Noora Noor</upnp:author>
upnp:genreSoul</upnp:genre>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/tc/9z/fxvojuywi9ztc_600.jpg</upnp:albumArtURI>
upnp:albumSoul Deep</upnp:album>
upnp:originalTrackNumber8</upnp:originalTrackNumber>
nextURI: http://192.168.0.156:49152/audirvana/audio_f_61.wav
Si Dolce È Il Tormento Paolo Fresu Paolo Fresu Claudio Monteverdi Jazz http://static.qobuz.com/images/covers/26/12/0614427981226_600.jpg Mare Nostrum II 12 object.item.audioItem.musicTrack http://192.168.0.156:49152/audirvana/audio_f_61.wav
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Next,Seek
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 Lyngdorf TDAI-1120 Lyngdorf http://lyngdorf.com/ TDAI-1120 http://lyngdorf.com/tdai-1120/ 2150006254 uuid:abde4097-5b06-480c-b1a8-845ac0ca98af image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.0.227/ DMR-1.51
UPnP devices found : 1
Device #0: Lyngdorf TDAI-1120
Location: http://192.168.0.227:36947/abde4097-5b06-480c-b1a8-845ac0ca98af.xml
Max. memory for audio buffers: 8192MB
Local devices found : 0
Chromecast devices found : 1
How does your system behave when using ASIO?
Thank you for the suggestion. I switched to ASIO, everything looks fine, but it may take a while before the issue re-appears (on average once a week, with the system in use at least 8 hours every day).
I’m not sure which ASIO driver it is using.
Does windows come with a standard driver?
If it is not predictably repeatable, the behavior points to your network configuration being the source… If you are using Wi-Fi somewhere in the transmission line to the TDA-1120, this presents a potential for data interruptions due to interference from RF and other wireless devices and networks… If this behavior occurs during streaming of digital-audio files from a streaming service, you could be experiencing interrupts from network congestion and/or broadband bandwidth/speed limitations…
I realise my previous reply was not entirely accurate. The Lyngdorf does not have an ethernet connection and connects to the LAN through WiFi. So, WiFi will always be involved, by design. And yes, other devices use the same network. For now I keep my fingers crossed that the switch to ASIO will have some effect.
Thanks again for your assistance.
In this report you are using Kernal Streaming, not ASIO.
The TDAI-1120 has an Ethernet connection and this is the is the recommended set-up by Lyngdorf… You will always be at the mercy of the Wi-Fi signal quality and broadband throughput… Also, I suggest lowering your playback pre-load memory allocation to 4GB.
I switched to ASIO following your advise.
And indeed, the Lyngdorf has an Ethernet connection and is connected that way. I was told otherwise as I didn’t install it myself.
Will try the pre-load allocation as well. Thanks!
It may still be connected to a Wi-Fi extender that gets its signal via Wi-Fi from your router… this is not recommended… I suggest you verify the pathway to the DAC.
Is there any way to set priorities for devices on the LAN, as in a managed switch, to give the highest priority to the Lyngdorf?
