Hello,
Not very new topic but I haven’t found anything that fixes my problem. As the title suggests, the playback stops randomly in the middle of a song.
Any help would be much appreciated. Below is the debug info…
Thanks!
Audirvana Origin 2.0.0 (20000)
Windows 10 (19044) with 8GB physical RAM
Connected account of : Joseph Martin
Sync list: 3 folders
AUTO: D:\MUSIQUE (sonos)
AUTO: F:\HYSOLID
AUTO: G:\JAZZNBLUESCLUB
Library database path: C:\Users\Joseph\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on fdf0:6f8a:7e87:0:d0ba:712c:c2be:56a6 on port 57678
Max. memory for audio buffers: 2774MB
Local Audio Engine: ASIO 2
Driver version 2
MOON USB HD DSD ASIO Driver
Model UID:MOON USB HD DSD ASIO Driver
Active Sample Rate: 2822.4kHz
Selected device:MOON USB HD DSD ASIO Driver
Manufacturer:
Model name: MOON USB HD DSD ASIO Driver
Model UID: MOON USB HD DSD ASIO Driver
17 available sample rates up to 45158400Hz
1411200
1536000
2822400
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
16 ch Integer PCM 32bit little endian 352.8kHz
16 ch Integer PCM 32bit little endian 384kHz
16 ch Integer PCM 32bit little endian 705.6kHz
16 ch Integer PCM 32bit little endian 768kHz
16 ch Integer PCM 32bit little endian 1411.2kHz
16 ch Integer PCM 32bit little endian 1536kHz
16 ch DSD 8bit big endian in 8bit chunk 2822.4kHz
16 ch DSD 8bit big endian in 8bit chunk 5644.8kHz
16 ch DSD 8bit big endian in 8bit chunk 11289.6kHz
16 ch DSD 8bit big endian in 8bit chunk 22579.2kHz
16 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Local devices found : 3
Device #0: Focusrite Thunderbolt ASIO
Manufacturer:
Model UID: Focusrite Thunderbolt ASIO
Model name: Focusrite Thunderbolt ASIO
Device #1: Focusrite USB ASIO
Manufacturer:
Model UID: Focusrite USB ASIO
Model name: Focusrite USB ASIO
Device #2: MOON USB HD DSD ASIO Driver
Manufacturer:
