Player progress bar freezes
Player progress bar freezes after the 3rd song. Album continues to play normally. Need support - THX.
Hi @dmpiedra,
It seems that work on Origin for Mac OS has been abandoned. Old bugs are not fixed, and only new ones appear with rare updates.
What is this?
I think I agree… Us Origin users are not such a good source of revenue…z On the upside, I’ve found Irigin to be do stable and ‘just works’ it’s perfect for my setup…
Hi @Andrey,
This once is an old bug and is here on both version of the software unfortunately. I did pass the bug to Damien as I have something in mind to tackle it but I can’t tell you when it will be fixed.
I just wanted to extend my thanks for your support in addressing the issues with Audirvana Origin for Windows and MacOS. Your effort in forwarding the need to the program responsibles or care team is greatly appreciated.
To reiterate the clear expectations from our part, it is essential that Audirvana Origin for both Windows and MacOS functions seamlessly with the Melco renderer. Specifically, we are seeking the elimination of freezing of the progress bar during playback. Additionally, for MacOS, it is crucial that the playback of the entire queue occurs without any interruptions or stops in the middle of the album.
The above-average sound quality of the Audirvana 2024 justifies the effort for you guys.
Progress bar issue: to illustrate: you drive a very high-sophisticated car
after the second turn, the car still drives well, but the tachometer freezes.
