I use Audirvana with an Auralic Aries streamer (upnp) connected to a DAC via USB. Both support DSD. However, DSD is greyed out in the device settings in Audirvana.
How can I get Audirvana to see that my devices support DSD?
Hello @b_machuel,
Can you send your debug info? You can find it in My account section of the settings of Studio.
Audirvana Mac Version 1.2.0 (10020)
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/Freebox/Musique
Library database path: /Users/benoit/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49180
Preferred device: AURALIC AURALIC ARIES UPNP Model UID:AURALIC Auralic aries uPnP UID:uuid:lightningRender-bc-34-00-a0-10-1f
UPnP device at http://192.168.0.154:33165/lightningRender-bc-34-00-a0-10-1f/Upnp/device.xml
ID 0x0 Auralic aries uPnP
Manufacturer: AURALIC
Model Name:
Model UID: AURALIC Auralic aries uPnP
UID: uuid:lightningRender-bc-34-00-a0-10-1f
Volume control: No
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/wave:
http-get::audio/x-wav:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/mp1:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x-ms-wma:
rtsp-rtp-udp::audio/x-ms-wma:
http-get::audio/x-scpls:
http-get::audio/x-mpegurl:
http-get::audio/x-ms-asf:
http-get::audio/x-ms-wax:
http-get::audio/x-ms-wvx:
http-get::text/xml:
http-get::audio/aac:
http-get::audio/aacp:
http-get::audio/mp4:
http-get::audio/ogg:
http-get::audio/x-ogg:
http-get::application/ogg:
http-get::video/mpeg:
http-get::video/mp4:
http-get::video/quicktime:
http-get::video/webm:
http-get::video/x-ms-wmv:
http-get::video/x-ms-asf:
http-get::video/x-msvideo:
http-get::video/x-ms-wax:
http-get::video/x-ms-wvx:
http-get::video/x-m4v:
http-get::video/x-matroska:
http-get::application/octet-stream:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
0 physical formats
CurrentSpeed: 0
NrTracks: 1
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 1 GetDeviceCapabilities InstanceID in A_ARG_TYPE_GetDeviceCapabilities_InstanceID PlayMedia out A_ARG_TYPE_GetDeviceCapabilities_PlayMedia RecMedia out A_ARG_TYPE_GetDeviceCapabilities_RecMedia RecQualityModes out A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes SetAVTransportURI InstanceID in A_ARG_TYPE_SetAVTransportURI_InstanceID CurrentURI in A_ARG_TYPE_SetAVTransportURI_CurrentURI CurrentURIMetaData in A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_SetNextAVTransportURI_InstanceID NextURI in A_ARG_TYPE_SetNextAVTransportURI_NextURI NextURIMetaData in A_ARG_TYPE_SetNextAVTransportURI_NextURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_GetMediaInfo_InstanceID NrTracks out A_ARG_TYPE_GetMediaInfo_NrTracks MediaDuration out A_ARG_TYPE_GetMediaInfo_MediaDuration CurrentURI out A_ARG_TYPE_GetMediaInfo_CurrentURI CurrentURIMetaData out A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData NextURI out A_ARG_TYPE_GetMediaInfo_NextURI NextURIMetaData out A_ARG_TYPE_GetMediaInfo_NextURIMetaData PlayMedium out A_ARG_TYPE_GetMediaInfo_PlayMedium RecordMedium out A_ARG_TYPE_GetMediaInfo_RecordMedium WriteStatus out A_ARG_TYPE_GetMediaInfo_WriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_GetTransportInfo_InstanceID CurrentTransportState out A_ARG_TYPE_GetTransportInfo_CurrentTransportState CurrentTransportStatus out A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus CurrentSpeed out A_ARG_TYPE_GetTransportInfo_CurrentSpeed GetPositionInfo InstanceID in A_ARG_TYPE_GetPositionInfo_InstanceID Track out A_ARG_TYPE_GetPositionInfo_Track TrackDuration out A_ARG_TYPE_GetPositionInfo_TrackDuration TrackMetaData out A_ARG_TYPE_GetPositionInfo_TrackMetaData TrackURI out A_ARG_TYPE_GetPositionInfo_TrackURI RelTime out A_ARG_TYPE_GetPositionInfo_RelTime AbsTime out A_ARG_TYPE_GetPositionInfo_AbsTime RelCount out A_ARG_TYPE_GetPositionInfo_RelCount AbsCount out A_ARG_TYPE_GetPositionInfo_AbsCount Stop InstanceID in A_ARG_TYPE_Stop_InstanceID Play InstanceID in A_ARG_TYPE_Play_InstanceID Speed in A_ARG_TYPE_Play_Speed Pause InstanceID in A_ARG_TYPE_Pause_InstanceID Seek InstanceID in A_ARG_TYPE_Seek_InstanceID Unit in A_ARG_TYPE_Seek_Unit Target in A_ARG_TYPE_Seek_Target Next InstanceID in A_ARG_TYPE_Next_InstanceID Previous InstanceID in A_ARG_TYPE_Previous_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_SetPlayMode_InstanceID NewPlayMode in A_ARG_TYPE_SetPlayMode_NewPlayMode GetTransportSettings InstanceID in A_ARG_TYPE_GetTransportSettings_InstanceID PlayMode out A_ARG_TYPE_GetTransportSettings_PlayMode RecQualityMode out A_ARG_TYPE_GetTransportSettings_RecQualityMode LastChange string A_ARG_TYPE_GetDeviceCapabilities_InstanceID ui4 A_ARG_TYPE_GetDeviceCapabilities_PlayMedia string A_ARG_TYPE_GetDeviceCapabilities_RecMedia string A_ARG_TYPE_GetDeviceCapabilities_RecQualityModes string A_ARG_TYPE_SetAVTransportURI_InstanceID ui4 A_ARG_TYPE_SetAVTransportURI_CurrentURI string A_ARG_TYPE_SetAVTransportURI_CurrentURIMetaData string A_ARG_TYPE_SetNextAVTransportURI_InstanceID ui4 A_ARG_TYPE_SetNextAVTransportURI_NextURI string A_ARG_TYPE_SetNextAVTransportURI_NextURIMetaData string A_ARG_TYPE_GetMediaInfo_InstanceID ui4 A_ARG_TYPE_GetMediaInfo_NrTracks ui4 A_ARG_TYPE_GetMediaInfo_MediaDuration string A_ARG_TYPE_GetMediaInfo_CurrentURI string A_ARG_TYPE_GetMediaInfo_CurrentURIMetaData string A_ARG_TYPE_GetMediaInfo_NextURI string A_ARG_TYPE_GetMediaInfo_NextURIMetaData string A_ARG_TYPE_GetMediaInfo_PlayMedium string A_ARG_TYPE_GetMediaInfo_RecordMedium string A_ARG_TYPE_GetMediaInfo_WriteStatus string NOT_IMPLEMENTED NOT_WRITABLE PROTECTED UNKNOWN WRITABLE A_ARG_TYPE_GetTransportInfo_InstanceID ui4 A_ARG_TYPE_GetTransportInfo_CurrentTransportState string NO_MEDIA_PRESENT PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING STOPPED TRANSITIONING A_ARG_TYPE_GetTransportInfo_CurrentTransportStatus string ERROR_OCCURRED OK A_ARG_TYPE_GetTransportInfo_CurrentSpeed string A_ARG_TYPE_GetPositionInfo_InstanceID ui4 A_ARG_TYPE_GetPositionInfo_Track ui4 0 2147483647 1 A_ARG_TYPE_GetPositionInfo_TrackDuration string A_ARG_TYPE_GetPositionInfo_TrackMetaData string A_ARG_TYPE_GetPositionInfo_TrackURI string A_ARG_TYPE_GetPositionInfo_RelTime string A_ARG_TYPE_GetPositionInfo_AbsTime string A_ARG_TYPE_GetPositionInfo_RelCount i4 A_ARG_TYPE_GetPositionInfo_AbsCount i4 A_ARG_TYPE_Stop_InstanceID ui4 A_ARG_TYPE_Play_InstanceID ui4 A_ARG_TYPE_Play_Speed string A_ARG_TYPE_Pause_InstanceID ui4 A_ARG_TYPE_Seek_InstanceID ui4 A_ARG_TYPE_Seek_Unit string ABS_COUNT ABS_TIME CHANNEL_FREQ FRAME REL_COUNT REL_TIME TAPE-INDEX TRACK_NR A_ARG_TYPE_Seek_Target string A_ARG_TYPE_Next_InstanceID ui4 A_ARG_TYPE_Previous_InstanceID ui4 A_ARG_TYPE_SetPlayMode_InstanceID ui4 A_ARG_TYPE_SetPlayMode_NewPlayMode string NORMAL A_ARG_TYPE_GetTransportSettings_InstanceID ui4 A_ARG_TYPE_GetTransportSettings_PlayMode string NORMAL A_ARG_TYPE_GetTransportSettings_RecQualityMode stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Auralic aries uPnP AURALIC ARIES uuid:lightningRender-bc-34-00-a0-10-1f urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-10-1f/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-10-1f/openhome.org-SubscriptionLongPoll-1/control urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/eventUPnP devices found : 4
Device #0: ID 0x0 HITACHI TV UID: uuid:13d49cb4-983e-1e4e-b690-7054b479180c Location: http://192.168.0.227:2870/dmr.xml
Device #1: ID 0x0 Mu-so Qb UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F090408 Location: http://192.168.0.35:8080/description.xml
Device #2: ID 0x0 Freebox Player UID: uuid:52cc5509-dca2-38a3-930d-61a21248bfdd Location: http://192.168.0.251:54243/device.xml
Device #3: ID 0x0 Auralic aries uPnP UID: uuid:lightningRender-bc-34-00-a0-10-1f Location: http://192.168.0.154:33165/lightningRender-bc-34-00-a0-10-1f/Upnp/device.xml
Max. memory for audio buffers: 936MB
Local devices found : 15
Device #0: ID 0x19a Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0x196 DisplayPort Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,0:0:{AC10-A057-304A304C} Model Name: Apple Inc. DisplayPort
Device #2: ID 0x34 Jabra Link 380 Manufacturer: Unknown Manufacturer Model UID: Jabra Link 380:0B0E:24C8 UID: AppleUSBAudioEngine:Unknown Manufacturer:Jabra Link 380:30507506D3E5:1 Model Name: Unknown Manufacturer Jabra Link 380
Device #3: ID 0x6d Boom2Device Manufacturer: globaldelight Model UID: com_globaldelight_driver_Boom2Device:Boom2Device UID: Boom2Engine:0 Model Name: globaldelight Boom2Device
Device #4: ID 0x44 MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice Model Name: MMAudio Device contributors MMAudio Device
Device #5: ID 0x49 MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds Model Name: MMAudio Device contributors MMAudio Device (UI Sounds)
Device #6: ID 0x62 Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #7: ID 0x55 Audiojingle Manufacturer: Audiojingle x Software Model UID: Soundtree UID: com.audiojinglex.soundtree.mastereffect Model Name: Audiojingle x Software Audiojingle
Device #8: ID 0x5a Audiojingle (UI Sounds) Manufacturer: Audiojingle x Software Model UID: Soundtree_UISounds UID: com.audiojinglex.soundtree.mastereffect.UISounds Model Name: Audiojingle x Software Audiojingle (UI Sounds)
Device #9: ID 0x1ab Headphones(S) Manufacturer: Static Z Software Model UID: Sound Bridge v3.1.0 UID: com.staticz.audio.directplay.AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Static Z Software Headphones(S)
Device #10: ID 0x1b2 DELL U2711(S) Manufacturer: Static Z Software Model UID: Sound Bridge v3.1.0 UID: com.staticz.audio.directplay.AppleHDAEngineOutputDP:1B,3,1,0:0:{AC10-A057-304A304C} Model Name: Static Z Software DELL U2711(S)
Device #11: ID 0x5e Jabra Link 380(S) Manufacturer: Static Z Software Model UID: Sound Bridge v3.1.0 UID: com.staticz.audio.directplay.AppleUSBAudioEngine:Unknown Manufacturer:Jabra Link 380:30507506D3E5:1 Model Name: Static Z Software Jabra Link 380(S)
Device #12: ID 0x18a Boom2Device(S) Manufacturer: Static Z Software Model UID: Sound Bridge v3.1.0 UID: com.staticz.audio.directplay.Boom2Engine:0 Model Name: Static Z Software Boom2Device(S)
Device #13: ID 0x84 Soundflower(S) Manufacturer: Static Z Software Model UID: Sound Bridge v3.1.0 UID: com.staticz.audio.directplay.SoundflowerEngine:0 Model Name: Static Z Software Soundflower(S)
Device #14: ID 0x3e ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
Bonjour,
Je n’ai toujours pas reçu de réponse à ma question de mai 2021 et le problème persiste.
Mdrci d’avance pour votre aide.
Bonjour @b_machuel,
Pouvez-vous envoyer une nouvelle fois votre debug info avec la dernière version de Audirvāna? J’ai une idée de pourquoi vous ne voyez pas le DSD lorsque vous sélectionnez votre Auralic.
Audirvana Studio 2.2.5 (20205)
macOS 13.2.1 with 32GB physical RAM
Connected account of : Benoît MACHUEL
Phase = 66%
SW volume control: ON
Listening on 127.0.0.1 on port 59149
Active method: UPnP
Preferred device: [UPnP] Aries mini uPnP Model UID:AURALIC ARIES_MINI UID:uuid:lightningRender-bc-34-00-a0-11-a8
Selected device:Aries mini uPnP
Model name: ARIES_MINI
Model UID: AURALIC ARIES_MINI
UID: uuid:lightningRender-bc-34-00-a0-11-a8
UPnP device at http://192.168.0.162:44237/lightningRender-bc-34-00-a0-11-a8/Upnp/device.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::text/xml:
DLNA 1.5: No
Native Gapless playback: Yes
Volume Control: dB
12 virtual formats:
0 physical formats
CurrentSpeed: 0
NrTracks: 1
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Aries mini uPnP AURALIC ARIES_MINI uuid:lightningRender-bc-34-00-a0-11-a8 urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-11-a8/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-11-a8/openhome.org-SubscriptionLongPoll-1/control urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-AVTransport-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-Roon-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-RenderingInfo-1/eventCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Aries mini uPnP AURALIC ARIES_MINI uuid:lightningRender-bc-34-00-a0-11-a8 urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-11-a8/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-11-a8/openhome.org-SubscriptionLongPoll-1/control urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-11-a8/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-11-a8/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-11-a8/upnp.org-AVTransport-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-Roon-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-11-a8/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-11-a8/av.openhome.org-RenderingInfo-1/eventUPnP devices found : 4
Device #0: ID 0x0 : Aries femto uPnP
Location: http://192.168.0.195:45466/lightningRender-bc-34-00-a0-10-1f/Upnp/device.xml
Model name: ARIES
Device #1: ID 0x0 : Mu-so Qb
Manufacturer: Naim Audio Ltd.
Model name: Mu-so Qb
Device #2: ID 0x0 : Aries mini uPnP
Location: http://192.168.0.162:44237/lightningRender-bc-34-00-a0-11-a8/Upnp/device.xml
Device #3: ID 0x0 : Freebox Player
Manufacturer: Freebox SAS
Model name: Freebox
Max. memory for audio buffers: 4108MB
Local Audio Engine: CoreAudio
Local devices found : 6
Device #0: ID 0x41 DELL U3421WE
Manufacturer: DEL
Model UID: 10AC81A1-0000-0000-1820-0104B5502178
Model name: DELL U3421WE
Device #1: ID 0x38 Jabra Link 380
USB Vendor ID: 0x0b0e
USB Product ID: 0x24c8
Model name: Unknown Manufacturer Jabra Link 380
Device #2: ID 0x79 Haut-parleurs Mac Studio
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs Mac Studio
Device #3: ID 0x50 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Device #4: ID 0x5a Jabra Link 380(S)
Model name: Static Z Software Jabra Link 380(S)
Device #5: ID 0x5f ZoomAudioDevice
Model name: zoom.us ZoomAudioDevice
Chromecast devices found : 1
Device #0: 32PFS6906/12
Model name: Philips FHD Android TV
DEBUG INFO POUR AURALIC ARIES FEMTO
Phase = 66%
Active method: UPnP
Preferred device: [UPnP] Aries femto uPnP Model UID:AURALIC ARIES UID:uuid:lightningRender-bc-34-00-a0-10-1f
Selected device:Aries femto uPnP
Model name: ARIES
UPnP device at http://192.168.0.195:45466/lightningRender-bc-34-00-a0-10-1f/Upnp/device.xml
ID 0x0
Volume control: Yes
http-get::text/xml:
DLNA 1.5: No
Volume Control: dB
12 virtual formats:
0 physical formats
CurrentSpeed: 0
NrTracks: 1
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Aries femto uPnP AURALIC ARIES uuid:lightningRender-bc-34-00-a0-10-1f urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-10-1f/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-10-1f/openhome.org-SubscriptionLongPoll-1/control urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Roon-1/event urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-Volume-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Volume-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Volume-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/eventCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Aries femto uPnP AURALIC ARIES uuid:lightningRender-bc-34-00-a0-10-1f urn:openhome-org:service:SubscriptionLongPoll:1 urn:openhome-org:serviceId:SubscriptionLongPoll /lightningRender-bc-34-00-a0-10-1f/Upnp/openhome.org-SubscriptionLongPoll-1/service.xml /lightningRender-bc-34-00-a0-10-1f/openhome.org-SubscriptionLongPoll-1/control urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-ConnectionManager-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-ConnectionManager-1/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-RenderingControl-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-RenderingControl-1/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /lightningRender-bc-34-00-a0-10-1f/Upnp/upnp.org-AVTransport-1/service.xml /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/control /lightningRender-bc-34-00-a0-10-1f/upnp.org-AVTransport-1/event urn:av-openhome-org:service:Roon:1 urn:av-openhome-org:serviceId:Roon /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-Roon-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Roon-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Roon-1/event urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-Volume-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Volume-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-Volume-1/event urn:av-openhome-org:service:HardwareConfig:1 urn:av-openhome-org:serviceId:HardwareConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-HardwareConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-HardwareConfig-1/event urn:av-openhome-org:service:MessageCenter:1 urn:av-openhome-org:serviceId:MessageCenter /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-MessageCenter-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-MessageCenter-1/event urn:av-openhome-org:service:WebRendererConfig:1 urn:av-openhome-org:serviceId:WebRendererConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebRendererConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebRendererConfig-1/event urn:av-openhome-org:service:WebProcessorConfig:1 urn:av-openhome-org:serviceId:WebProcessorConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebProcessorConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebProcessorConfig-1/event urn:av-openhome-org:service:WebDeviceConfig:1 urn:av-openhome-org:serviceId:WebDeviceConfig /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-WebDeviceConfig-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-WebDeviceConfig-1/event urn:av-openhome-org:service:RenderingInfo:1 urn:av-openhome-org:serviceId:RenderingInfo /lightningRender-bc-34-00-a0-10-1f/Upnp/av.openhome.org-RenderingInfo-1/service.xml /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/control /lightningRender-bc-34-00-a0-10-1f/av.openhome.org-RenderingInfo-1/eventUPnP devices found : 4
Model name: ARIES
Model name: Freebox
Manufacturer: DEL
Model UID: Speaker
Voici un appareil qui nous indique qu’il peut bien supporter DSD nativement en UPnP:
http-get::audio/mp3:
http-get::audio/mpeg3:
http-get::audio/x-mpeg3:
http-get::audio/vorbis:
http-get::audio/flac:
http-get::audio/m4a:
http-get::audio/wma:
http-get::audio/dsd:
http-get::audio/dsf:
http-get::audio/dff:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
Votre appareil ne mentionne pas cela:
Il doit donc utiliser le DoP pour pouvoir faire cela. Si vous activez le DSD Over PCM, vous devriez pouvoir lire des pistes allant au delà de 192Khz.
L’aries femto est supposé gérer jusqu’au DSD64. Le fait que je doive le mettre en upnp afin d’être vu par audirvana peut-il être la raison de cette disparition du DSD natif ?
MacOS does not transfer raw DSD signals… all DSDxxx is transferred via DoP 1.1 …
I don’t see this device is supporting DSD…
The Aries femto has two connection modes: upnp and ‘lightning device’. Audirvana does not see the Aries when it is set to lightning mode, but roon does and actually plays DSD on it like a charm.
If the Aries was not capable of playing DSD, Roon would automatically convert the DSD signal to PCM before sending it to the device.
Roon is not using UPnP, they use their own protocol so you can’t use to compare. However, of you have a Android device, you can use Bubble UPnP and try to check your device capability, you will also see it says it doesn’t support DSD natively but keep in mind that Auralic as a way of saying “DSD supported” as you can see on the specs of the G1.1 for example
DSD: DSD64(2.8224MHz), DSD128(5.6448MHz), DSD256(11.2896MHz), DSD512(22.57892MHz)****
**** By ‘DoP V1.1’ or native DSD protocol through streaming and USB inputs only
