My Marantz NA 11s1 specs shows that it doesn’t support MQA under the list of compatible formats.
When I play a FLAC MQA | 24/44.1 and select Not MQA option, it shows the DAC: 24/88.2.
The NA-11s1 plays the song correctly and shows it playing at 88.2.
When I play a FLAC MQA | 24/44.1 and enable the MQA Renderer option, it shows the DAC: 24/88.2.
When I play a FLAC MQA | 24/44.1 and enable the MQA Decoder option, it shows the DAC: 24/44.1.
The NA-11s1 plays the song correctly and shows it playing at 44.1.
Few questions here:
If the file is 44.1khz, why is it being outputted at 88.2 kHz for the first two options.
So, if you have a DAC that decodes up to 24/192 but that’s not MQA compatible, and your playing a 24/44.1 MQA file, Audirvāna unfolds it so that it outputs at a true 24/44.8, correct?
