Playlist on headless installation
Hello
Is it possible to copy saved playlists from my windows studio installation to an headless Linux installation?
What Im trying to do is to add URLs of radio stations so they can be saved in playlist (so I wont have to add them again). This works fine on my windows setup so now I try to find a way to configure it on my linux box. AFAIK there is no option to add an URL using the Audirvana remote.
Hi @simon12,
This option is not available on the Remote you have as of today. We are working on this and you will be able to do this in a future update of the Remote app.
