network to a Trinnov Altitude 16 then spdif to a Meiner MA-3 DAC
timer does not advance and it stops at the end of each song UNLESS I enable upsampling THEN it will play a second song and timer stops with 2 seconds to go at the end of the first song THEN it plays the next song but the timer stays at 2 seconds to go and it stops at the end of that second track
manually advance to the next song and it does the same thing again,
Damn foiled again, have you toggled the raw/pcm switch? Buffer size can be adjusted as required also.
I’m sure @Antoine will see this but you should submit your debug information to [email protected] He always request to look that over. Look thru the UPNP topic post and perhaps pick up some pointers.
Don’t feel too lonely, they have managed to completely stop my Oppo DAC from working via wireless UPNP again…….
Hey @bwbos , An update. After I realized my local files were no longer playing via usb or UPNP I have moved back to 1.22.0 and my Oppo DAC is working wireless again……go figure. I think your use of hdmi is pretty slick thinking and probably the most stable connection as you have noticed that many of us have a lot of heartburn with Ethernet UPNP and wireless connection. Enjoy your music over the weekend!
