Using TDR plugin but not working in realtime.
I was well working with Adirvana 3.5 on mac.
Hello @TRS38,
Are you playing DSD track or playing to a network device when you have this behavior?
Hello Antoine
Of course not dsd tracks.
Not network device. Only a DAC
Jacques
Audirvana Origin 1.0.2 (10002)
Windows 11 (22616) with 16GB physical RAM
Connected account of : Jacques TROVEL
VST3 plugin #0: C:\Program Files\Common Files\VST3\TDR Nova.vst3
ClassID: 56535454643561746472206E6F766100
VST3 plugin #1: C:\Program Files\Common Files\VST3\BC Triple EQ 4 VST3(Stereo).vst3
ClassID: F038B4F4FA684A0AA3DC280D0875069F
VST3 plugin #2: None
VST3 plugin #3: None
SoX custom frequencies
Bandwidth at 0dB = 99.5%
Phase = 66%
Max allowed volume: 24.5699
Replay Gain: by track
SW volume control: ON
AUTO: C:\Users\33767\Music
Library database path: C:\Users\33767\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:cb15:8455:100:a808:286a:6c0c:d158 on port 63439
Max. memory for audio buffers: 3152MB
Haut-parleurs (SMSL USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0104&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{4ae56412-3a86-4325-8e0c-d22bd2785fd6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Manufacturer: XMOS
Model Name: Unknown manufacturer
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0104&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d751d2f7-442f-43d7-a8e6-e5c2dd4faf8c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Local devices found : 3
Device #0: Haut-parleurs (SMSL USB DAC) Manufacturer: XMOS Model UID: TUSBAUDIO_ENUM\VID_152A&PID_85DD&REV_0104&KS UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d751d2f7-442f-43d7-a8e6-e5c2dd4faf8c}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Enceintes (Realtek(R) Audio) Manufacturer: Realtek Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0236&SUBSYS_10280A7E&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{82f3e01b-4c78-45fd-87b0-2fe0c11351f5}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Realtek(R) Audio
Device #2: PHL 246E7 (HD Audio Driver for Display Audio) Manufacturer: Intel Corporation Model UID: HDAUDIO\SUBFUNC_01&VEN_8086&DEV_2812&NID_0001&SUBSYS_00000000&REV_1000 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8c228831-65fc-4a26-8f04-d9e18217d666}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Pouvez-vous désactiver le suréchantillonnage et refaire un test?
Test fait …toujours rien
Avez-vous aussi essayer de réinstaller le plugin?
oui c est la première chose que j ai faite.
Bonjour Antoine
Toujours pas d idée?
Jacques
Quand je regarde le fichir debug…je remarque que le VTS #1 n 'est as installé.
l fichier : VST3 plugin #1: C:\Program Files\Common Files\VST3\BC Triple EQ 4 VST3(Stereo).vst3 n existe plus.
C 'est curieux que le debug le vois toujours
Bonjour @TRS38,
Pouvez-vous essayer de sélectionner un autre plugin que le BC Triple?
je n utilise pas le plugin BR.
je la avis installé voir voir si lui fonctionnenait mais …pas mieux que TDR.
de plus Audirvana semble toujours voir BR alors qu il a été désinstallé et que les fichiers n existent plus!
Si vous cliquez sur Configurer à côté du plugin sélectionné, que voyez-vous?
Le plugin s ouve coorectement et fonctionne.
Mais pas en temps réel
C est BC Triple EQ qui met la pagaille alors qu il n 'st plus présent sur le PC…mais audirvana cherche toujours a l ouvrir…!!
2022-05-18 15:00:16,006 [1] INFO Audirvana.App - ============= Started Logging, Audirvana 1.0.4 =============
2022-05-18 15:00:17,096 [6] DEBUG Audirvana.App - UPnP: Error obtaining device description from http://192.168.1.13:9080 – error = -107
2022-05-18 15:00:17,416 [1] DEBUG Audirvana.App - ASIO: start selecting driver USB DAC ASIO
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: init for USB DAC ASIO
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: call init
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: init done
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: got out channels: 2
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: init step 2
2022-05-18 15:00:17,426 [1] DEBUG Audirvana.App - ASIO: init step 3
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 4
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5b
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5c: 2822400.000000
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5c: 5644800.000000
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5c: 11289600.000000
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 5c: 22579200.000000
2022-05-18 15:00:17,460 [1] DEBUG Audirvana.App - ASIO: init step 6
2022-05-18 15:00:17,487 [1] DEBUG Audirvana.App - ASIO: init step 7
2022-05-18 15:00:17,487 [1] DEBUG Audirvana.App - ASIO: init step 8
2022-05-18 15:00:17,487 [1] DEBUG Audirvana.App - ASIO: init step 9
2022-05-18 15:00:17,493 [1] DEBUG Audirvana.App - ASIO: init step 10
2022-05-18 15:00:18,306 [13] DEBUG Audirvana.App - UPnP: Error obtaining device description from http://192.168.1.13:9080 – error = -107
2022-05-18 15:00:18,817 [14] DEBUG Audirvana.App - RemoteServer: Server started and advertised on port 53620
2022-05-18 15:01:15,070 [1] DEBUG Audirvana.App - ASIO: start step 1
2022-05-18 15:01:15,070 [1] DEBUG Audirvana.App - ASIO: start step 2
2022-05-18 15:01:15,109 [1] DEBUG Audirvana.App - ASIO: start step 3
2022-05-18 15:01:15,109 [1] DEBUG Audirvana.App - ASIO: start step 4 with 2 channels
2022-05-18 15:01:15,582 [1] DEBUG Audirvana.App - ASIO: start step 5
2022-05-18 15:01:15,582 [1] DEBUG Audirvana.App - ASIO: start step 6
2022-05-18 15:01:15,603 [1] DEBUG Audirvana.App - VST editor: error LoadLibray failed: Le module sp?cifi? est introuvable.
opening C:\Program Files\Common Files\VST3\BC Triple EQ 4 VST3(Stereo).vst3
Il n’est vraiment plus dans le dossier C:\Program Files\Common Files\VST3\ ?
Non plus du tout…
J ai même fait une recherche sur ton mon pc pour être sûr…plus aucune trace.
D ailleurs il n apparaît plus dans l onglet plugin d Audirvana…
