Plugins don't work with Marantz PM7000N
Hi, the plugins don’t work with Marantz PM7000N.
I can no longer use any plug-in while playing a music, simply dont’t show the plug-in popup. Besides, I think the plugins not are working even at background. I remember that at one time you had resolved this, but now the problem has returned.
Please paste your Debug information here, so folks can help you the best possible… it is found here: Settings–> My Account–> Help–> Debug information.
Plug-ins operate on the signals presented to them and the results are output to the destination device which has nothing to do with how the plug-in works… You may want to contact the plug-in designer to get some insights on the behavior… Compatibility can change with updates.
Audirvana Studio 2.8.2 (20802)
Windows 10 (19045) with 16GB physical RAM
Connected account of : Alex Lins
Available network interfaces:
brisa-1742405 ({3551f873-0135-474d-bafb-a5f463fef662}) is private
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Third party firewall installed and registered in place of Windows Defender:
Kaspersky Standard
	VST3 plugin #0: C:\Program Files\Common Files\VST3\MeldaProduction\EQ\MEqualizer.vst3
		ClassID: 4D656C646170726F4D4165334D416533
	VST3 plugin #1: None
	VST3 plugin #2: None
	VST3 plugin #3: None
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: C:\Users\AlexLins\Documents\DRmare TidiKit Music Converter\Converted
Library database path: C:\Users\AlexLins\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 166
Listening on 2804:29b8:5161:9c4:24d2:80f2:11a7:c0f0 on port 65043
TIDAL: Connected as PREMIUM
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] Marantz PM7000N Model UID:Marantz Marantz PM7000N UID:uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6
Selected device:Marantz PM7000N
Manufacturer: Marantz
Model name: Marantz PM7000N
Model UID: Marantz Marantz PM7000N
UID: uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6
UPnP device at http://192.168.0.4:60006/upnp/desc/aios_device/aios_device.xml
Volume control: Yes
Not automatically detected, user set to MQA Renderer
DSD via PCM 1.1
UPnP set capabilities
Maximum PCM bitdepth set: 16
Not native DSD capable
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.0.15:49152/audirvana/audioTest.pcm
CurrentURIMetadata: dc:titletestTitle</dc:title>http://192.168.0.15:49152/audirvana/audioTest.pcmupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creator""</dc:creator>upnp:genre""</upnp:genre>upnp:artist""</upnp:artist>upnp:album""</upnp:album>upnp:albumArtURI""</upnp:albumArtURI>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play,Stop,Next,Previous
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27190900280 uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6 urn:schemas-upnp-org:device:MediaRenderer:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:bd84ddb6-c891-1b76-0080-0005cdb3dbd6 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:4b2ad4aa-1fc3-1eee-0080-0005cdb3dbd6 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27190900280 uuid:77cfb03f-186d-408d-d12f-e5a82b56477f AIOS:0001 2 1715779858 Thu 2024-05-16 00:31:04 3.19.350 00:05:CD:B3:DB:D4 en_NA 4 Aios 4.025 1 Production 00:05:CD:B3:DB:D6 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Marantz PM7000N Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz PM7000N Aios 4.025 BLL27190900280 uuid:cb238573-c03e-bbed-ddac-9f72c1c6a021 True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManager
UPnP devices found : 2
Device #0: Marantz PM7000N
Location: http://192.168.0.4:60006/upnp/desc/aios_device/aios_device.xml
Device #1: JPLAY FEMTO
UID: uuid:JPLAY127.0.0.1-MediaRenderer
Location: http://192.168.0.15:48167/JPLAY127.0.0.1-MediaRenderer/Upnp/device.xml
Manufacturer: jplay.eu
Model name: JPLAY
Max. memory for audio buffers: 10460MB
Local devices found : 3
Device #0: LG IPS FULLHD (Áudio Intel(R) para telas)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_2807&SUBSYS_15586555&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{613bf699-596f-4994-af41-4c19bcb83851}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Alto-falantes (High Definition Audio Device)
Manufacturer: Microsoft
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_15586555&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7ffb51b3-46a2-47e1-b7e0-e0edb69b2505}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Áudio Digital (S/PDIF) (High Definition Audio Device)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{ab60acf9-b134-4ba6-8593-2865a3ac3f55}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Why are you not using ASIO or WASAPI?
Also, lower your playback pre-load memory allocation to 4GB… You are allocating approximately 60% of your System RAM for playback pre-load memory.
Hi Agoldnear,
I made the changes you suggested, but the plugin popup still doesn’t appear. Bellow is the new debug info:
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Kaspersky Standard
Phase = 66%
Tracks with no MBID: 167
Listening on 2804:29b8:5161:9c4:24d2:80f2:11a7:c0f0 on port 64527
Font size: regular
My Music
Radios
Podcasts
Streaming
Active method: UPnP
Volume control: Yes
DLNA 1.5: No
NrTracks: 1
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
UID: uuid:JPLAY192.168.0.15-MediaRenderer
Location: http://192.168.0.15:48167/JPLAY192.168.0.15-MediaRenderer/Upnp/device.xml
Model name: JPLAY
Max. memory for audio buffers: 4096MB
Local Audio Engine: ASIO 0
Driver version 0
Device #0: JPLAY Driver
Manufacturer:
Model UID: JPLAY Driver
UID: JPLAY Driver
Model name: JPLAY Driver
Have you tried disabling your virus software and removing the ‘JPLAY Driver’ software?
In regard to the virus software, maybe it see the plug-ins as a potential threat… The JPLAY Driver is competing with Audirvana for I/O specific API’s.
If you are trying to play DSD files (We see that you are converting DSD to PCM) You will not be able to apply DSP processing to 1-bit DSD signals… The plug-in module will not be available.
From the debug report:
Hi,
I made the changes you asked for, but the plugin popup still doesn’t appear. I set DSD capability to “DSD over PCM 1.0”. I think it’s a incompatibility problem between Marantz and Audirvana. Bellow is the new debug info:
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Kaspersky Standard
Phase = 66%
Tracks with no MBID: 169
Listening on 2804:29b8:5161:9c4:24d2:80f2:11a7:c0f0 on port 51766
Font size: regular
My Music
Radios
Podcasts
Streaming
Active method: UPnP
Currently playing to UPnP device at 16 bits 192kHz
Volume control: Yes
DSD via PCM 1.0
DLNA 1.5: No
NrTracks: 1
CurrentURI: http://192.168.0.15:49152/audirvana/audio_f_6.wav
CurrentURIMetadata: dc:titleO Sole Mio</dc:title>http://192.168.0.15:49152/audirvana/audio_f_6.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorAndré Rieu</dc:creator>upnp:genre""</upnp:genre>upnp:artistAndré Rieu</upnp:artist>upnp:albumLove In Venice</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/846993ab/a59e/40fc/aff2/93a7c17ee06e/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber1</upnp:originalTrackNumber>
nextURI: http://192.168.0.15:49152/audirvana/audio_f_7.wav
nextURIMetadata: dc:titleVolare</dc:title>http://192.168.0.15:49152/audirvana/audio_f_7.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorAndré Rieu</dc:creator>upnp:genre""</upnp:genre>upnp:artistAndré Rieu</upnp:artist>upnp:albumLove In Venice</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/846993ab/a59e/40fc/aff2/93a7c17ee06e/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber2</upnp:originalTrackNumber>
PlayMedium: NETWORK
Play,Stop,Previous,Pause,Restart
UPnP devices found : 1
Local Audio Engine: ASIO 7209071
Driver version 7864421
Local devices found : 0
Yes this is a long known problem that audirvana is not able to play DSD to Marantz PM7000N. And possibly to other HEOS devices.
I’ve been asking for a fix for years.
We see in the debug report that the UPnP protocol for the device does not support native DSD… The maximum DSD sample-rate this could possibly support is 2.8MHz (DSD64) via DoP (DSD over PCM) as the PCM carrier sample-rate for DSD64 (2.8MHz) is 24/176.4kHz, However, you will never get plug-in functionality when playing 1-bit DSD files.
It looks to me, the PM7000N can play DSD files up-to 5.6MHz (DSD128) via an attached USB storage device on the USB-A port.
From the Owners Manual: (Note the bold text)
Playing back files stored on a PC and NAS
This unit is compatible with MP3 ID3-Tag (Ver. 2) standard.
This unit is compatible with WMA META tags.
If the image size (pixels) of an album artwork exceeds 500 × 500 (WMA/MP3/WAV/FLAC) or 349 × 349 (MPEG-4 AAC), then music may not be played back properly.
A server or server software compatible with distribution in the corresponding formats is required to play music files via a network
For playing mentioned audio formats via a network a server software, for example Twonky Media Server or jRiver Media Server, needs to be installed on your computer or NAS for full support. There are other server software available too. Please check supported formats.
Specifications of supported files
Sam­pling fre­quency Bit rate Ex­ten­sion
WMA∗1 32/44.1/48 kHz 48 – 192 kbps .wma
MP3 32/44.1/48 kHz 32 – 320 kbps .mp3
WAV 32/44.1/48/88.2/96/176.4/192kHz .wav
MPEG-4 AAC∗1 32/44.1/48 kHz 48 – 320 kbps .aac/.m4a
FLAC 44.1/48/88.2/96/176.4/192 kHz .flac
Apple Loss­less∗2 44.1/48/88.2/96/176.4/192 kHz .m4a
DSD 2.8/5.6 MHz .dsf/.dff
Only files that are not protected by copyright can be played on this unit.
Hum… This issue occurs with any Tidal music format (flac, mqa, dsd) that I try to play. I remember there was a time when they had solved this problem and the plugin popup appeared and worked normally during playback.
Yes, and it happens with any local downloaded DSD file w/o any plugins enabled, if you try to play them to PM7000N via UPNP.
The primary issue regarding plug-in visibility/functionality when playing to a UPnP endpoint has been addressed by @Antoine here:
It worked, although the popup didn’t appear during playback. Thanks!
