Pop Noise Between DSF/DSD tracks/Pop Noise entre les pistes DSF/DSD
My platform is a MacBook Air M4. When I play a dsf/dsd album on it through Audirvana Studio, there is a noticeable “pop” between tracks. Has anyone else experienced this? Has anyone found a fix for it? Ma plate-forme est un MacBook Air M4. Lorsque je joue un album dsf/dsd dessus via Audirvana Studio, il y a un “pop” notable entre les pistes. Quelqu’un d’autre a-t-il vécu cela ? Quelqu’un a-t-il trouvé une solution pour cela ?
Welcome…
Please paste your debug information report here so folks can see the synergy of the computer platform and Audirvāna… You can find it here…
This article will provide insight into the conditions that precipitate this noise…
Adding sample-rate change latency and muting during sample-rate changes in the Audirvāna settings, is the best you can do… however, other computer platform/system related elements can play into this noise, like the amount of System RAM available vs playback pre-load memory allocation, this relationship is important in all aspects of the playback experience and the performance of the Audirvāna audio-engine and DSP.
Audirvana Studio 2.11.0 (21100)
macOS Version 15.5 (Build 24F74) ARM64 with 16GB physical RAM
Connected account of : William Rexrode
Local network access: allowed
DSP NOT ACTIVE
Sync list: 20 folders
Manual: /Users/william/.Trash/Big Vivaldi Box
AUTO: /Users/william/Music/Andrew Lahiff - Quiet Spaces and Distant Dreams
AUTO: /Users/william/Music/Blue-Coast-Collection
AUTO: /Users/william/Music/Chandos Downloads
AUTO: /Users/william/Music/Constellations
AUTO: /Users/william/Music/Data Lords
AUTO: /Users/william/Music/eClassical
AUTO: /Users/william/Music/HDtracks
AUTO: /Users/william/Music/Hyperion
AUTO: /Users/william/Music/Johann Sebastian Bach Complete Organ Works
AUTO: /Users/william/Music/Linn Music
AUTO: /Users/william/Music/Morell - Concerto for Guitar and Jazz Orchestra
AUTO: /Users/william/Music/Music/Music 1/Media/Music
AUTO: /Users/william/Music/NativeDSD
AUTO: /Users/william/Music/NativeDSD 512
AUTO: /Users/william/Music/Naxos
AUTO: /Users/william/Music/Presto Classical
AUTO: /Users/william/Music/ProStudio Masters
AUTO: /Users/william/Music/Qobuz
AUTO: /Users/william/Music/SMT_189
Sync folders at startup: YES
Sort and display order: en_US
Library database path: /Users/william/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 6782
Listening on on port 65062
Font size: large
Streaming
My Music
Radios
Podcasts
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Actual I/O buffer frame size: 1024
Apple Inc. Focal Bathys
Model UID:ffff a
UID:2C-27-9E-71-2C-9D:output
Hog Mode is on
Selected device:Focal Bathys
Model name: Apple Inc. Focal Bathys
Model UID: ffff a
UID: 2C-27-9E-71-2C-9D:output
ID 0x7c
2 available sample rates up to 44100Hz
16000
Audio buffer frame size : 14 to 1024 frames
Current I/O buffer frame size : 1024
DSD via PCM 1.1
Stream ID 0x7d 2 channels starting at 1
2 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 16kHz
2 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 16kHz
Local devices found : 3
Device #0: ID 0x7c Focal Bathys
Model UID: ffff a
Device #1: ID 0x47 MacBook Air Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x53 Speaker Audio Recorder
Manufacturer: Speaker Audio Recorder
Model UID: SPRDeviceModelUID
UID: SPRDevice
Model name: Speaker Audio Recorder
Wi-Fi
UPnP devices found : 1
Device #0: ID 0x0 : 55" QLED
UID: uuid:17e62f4b-7b9c-43ef-8276-17059dc3a54a
Manufacturer: Samsung Electronics
Model name: QN55Q72DDFXZA
Are you using the Bathys on Bluetooth? Because the debug report is showing it capable to 32 bit/44.1kHz when the specification for USB DAC mode capability is 24 bit/192kHz… the Focal Bathys do not support DSD playback… To playback DSD files, you will need to configure Audirvāna to ‘covert to PCM’.
[quote=“fsasya, post:3, topic:44731”]
***[/***quote]
You are using 13.3GB of your 16GB of System RAM for playback pre-load memory… I suggest lowering the pre-load memory allocation to 4GB to 6GB… In general, more System RAM available for processing is better for overall performance… It is a balance that will depend on your playback strategy…
I was using blue tooth headphones at the time I took the debug readings, but the pop also
occurs with wired headphones connected directly to my Mac and with a USB connection to a Hugo tt2 dac/amp. I will try your suggested changes.
Hi @fsasya,
Can you please take a look at the note at the end of this article?
