It started after installing 2.2.3. I am playing from Windows 11. The pops and crackles happen from USB and bluetooth. I’ve used 3 different dacs, kernal streaming and Wasapi. It happens without using any VST plug-in. My system memory is set to 2498, that’s all it allows. It happens with headphones and speakers, and with or without software volume control. The sound is good until I play a moderate volume track with strong bass frequencies, and once the crackling starts, every track after that will crackle even at minimum volume. I re-installed Studio 2.2.3 again, but that did not fix the problem.
Backing out to v 2.2.2 made no difference.
