Primare NP5 UPnP issues
Using Primare NP5 as an UPnP device through Audirvana is an absolute joke. Every track either rewinds to the beginning or there is loud white noise blasting out of nowhere. Anybody have any solutions?
Here’s my debug info
Audirvana Mac Version 3.5.37 (3567)
macOS 10.16.0 with 8192MB RAM
Registered to Klodian Ozuni
	Per track: OFF
SW volume control: ON
Sync list: 3 folders
AUTO: /Users/klodianozuni/Dropbox/Personal/Music/DSD
AUTO: /Users/klodianozuni/Dropbox/Personal/Music/FLAC
AUTO: /Users/klodianozuni/Dropbox/Personal/Music/Random MP3
iTunes/Music library synchronization: last synchronized on Mon Nov 2 13:32:13 2020
Library database path: /Users/klodianozuni/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: Primare NP5 Model UID:Primare Primare NP5 UID:uuid:6adf226c-6dc7-11eb-b8e7-df7a993b73da
UPnP device at http://192.168.1.158:38400/description.xml
ID 0x0 Primare NP5 Manufacturer:Primare
Volume control: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:
:audio/flac:*
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
http-get:
http-get:
:audio/aiff:*
http-get::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:04:05.000
CurrentURI: http://192.168.1.186:49153/audirvana/audio_0_46.wav
CurrentURIMetadata:
dc:titleGreen Papaya</dc:title>
dc:creatorLianne La Havas</dc:creator>
upnp:artistLianne La Havas</upnp:artist>
upnp:genreSoul</upnp:genre>
upnp:albumArtURIhttp://192.168.1.186:49153/audirvana/artwork_0_47.jpg</upnp:albumArtURI>
upnp:albumLianne La Havas</upnp:album>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
nextURI: http://192.168.1.186:49153/audirvana/audio_1_47.wav
Can't Fight Lianne La Havas Lianne La Havas Soul http://192.168.1.186:49153/audirvana/artwork_1_48.jpg Lianne La Havas 4 object.item.audioItem.musicTrack http://192.168.1.186:49153/audirvana/audio_1_47.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 Primare NP5 Primare http://www.primare.net/ PrimareDMR Primare NP5 1.0 http://www.primare.net/products/np5-prisma/ 1234567890 uuid:6adf226c-6dc7-11eb-b8e7-df7a993b73da http://192.168.1.158 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.1.158:38400
UPnP devices found : 3
Device #0: ID 0x0 DIXONS-JVC TV UID: uuid:140ab02e-1e10-11b2-be1d-0009df883426 Location: http://192.168.1.210:2870/dmr.xml
Device #1: ID 0x0 Primare NP5 UID: uuid:6adf226c-6dc7-11eb-b8e7-df7a993b73da Location: http://192.168.1.158:38400/description.xml
Device #2: ID 0x0 BubbleUPnP (SM-G975F) UID: uuid:866975da-ad80-451e-bb27-0629589e847e Location: http://192.168.1.131:58645/dev/866975da-ad80-451e-bb27-0629589e847e/desc.xml
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
Unfortunately you‘ll have to contact Primare for this.
You can also try to reduce the pre-load cache to 2000MB, and see if that helps. The way you described the problem I doubt it though. Still, it’s worth a try.
I’ll try that, thank you.
