I just got a Streambox as a gift and I can only get Audirvana to see it when the Streambox is hook to the internet via ethernet. When I switch to wifi, the Streambox option disappears from the menu. The Streambox APP works fine with Wifi so I know it’s hooked up.
Yes, restarted both the program and then restarted the whole computer and relaunched the program. It never sees it over wifi. If I enter the IP address into a browser, I’m able to pull up the Pro-Ject interface fine so I know it’s on the network properly.
