Why I cannot play 24 bit 96khz files. Audirvana plays the song. But no sound is output. For the same set up iTunes has no issue with output
To better understand… could you please describe your setup?
macOS/Windows, Audirvana version, dac used
MAC mini Mojave 10.14.6
Dac Cambridge audio dac magic 3
Audirvana 3.5.37 (3567)
I suppose it is the Dac Magic Plus … can you post the screenshot of the Audirvana dac settings? … with the dac connected
noe i notiser it has. a prob w 48Khz as well. I
Did you enabled USB Class 2 on your dac?
… see at the bottom of page 22
Sorry, the model of my dac is Dac Magic (older version) I am not sure if there is such a setting on this model
On page 14 the instructions to set USB Class 2 for the Dac Magic 100
The model is just dac magic , precursor to these models
… no chance to find a user manual …
Can you post a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
I could find a review of the “original” DacMagic here https://www.stereophile.com/content/cambridge-audio-azur-dacmagic-da-converter-specifications
and it seems it can accept on usb just 44.1 and 48 (I suppose 16 bits)
Dear All,
If it helps, the PDF User Guide file for the Cambridge Audio Azur DacMagic can be found here:
Audirvana Mac Version 3.5.37 (3567)
macOS 10.14.6 with 8192MB RAM
Registered to kenneth hee
AUTO: /Volumes/NO NAME/music server
Library database path: /Users/29firstmediacenter/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
DisplayPort
Model UID:AppleGFXHDA:0
UID:AppleGFXHDAEngineOutputDP:0:{6D1E-0001-01010101}
ID 0x58 DisplayPort Manufacturer:Apple Inc.
Model UID:AppleGFXHDA:0 UID:AppleGFXHDAEngineOutputDP:0:{6D1E-0001-01010101}
5 available sample rates up to 192000Hz
32000
Stream ID 0x59 2 channels starting at 1
5 virtual formats:
10 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x58 DisplayPort Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:0:{6D1E-0001-01010101}
Device #1: ID 0x4c Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 [TV][LG]29firstcast UID: uuid:664ac9f3-1c29-2bba-fe1b-d83608dfcb12 Location: http://192.168.1.128:1245/
how do I switch this? the upsampling selection in aurivarna is not selectable
To change this setting you need to stop your audio playback in Audirvana. Can you do it and try to change your upsampling settings?
stopped playback. still not selectable
ok. managed to deactivate and it plays. so the question is why is this an issue?
