Problem »Error starting device playback« still present :-(
Hi there!
After upgrading my system (better laptop, Windows 11, better DAC), I am still bothered by that nasty »Unable to change to Integer Mode« problem … :see_no_evil:
»Kernel-Streaming« is my default setting, and when starting Audirvāna, I almost always get that »Unable to change to Integer Mode« message. What I usually do then is switching to »WASAPI«, start playback any song, stop that, and switch back to »Kernel-Streaming«. Which works from that moment on without any problems, as long as that given Audirvāna listening session may last. What sense does that make?
Hi @Audi100,
It makes sense, It’s probably kind of a initialisation that is not working properly. I will have to take a closer look about it as soon as possible.
I see. Nevertheless I’d appreciate it quite a lot if it won’t happen again.
Uh – seems I have to correct myself. The error message goes like:
Sorry for any confusion … :face_with_diagonal_mouth:
OK – I seem to get both messages in a mysteriously mixed sequence. Today it maybe the Integer-Mode one, tomorrow the Device-Playback one
Nearly six weeks later (and with Studio 2.6.2 now) the problem is still alive and kicking
