Hi all, ran into a bit of an issue as I am trying Audirvana for the first time. Set up is laptop w/ Tidal in Audirvana ->hdmi->Tv->optical->Bluesound 2i-> amp. Plays fine on the laptop, but when I plug it into the HDMI to go through my speakers it suddenly becomes unplayable, sounds like it is constantly trying to buffer and is stopping.
I tried lowering the Max memory allocated for tracks pre-load to the lowest, but that didnt seem to help. Thanks in advance for any help.
debug below:
Audirvana 3.5.43
Sync list: 0 folders
Library database path: C:\Users\John\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1004MB
Local Audio Engine:WASAPI
Speakers (Realtek High Definition Audio(SST))
Model UID:Speakers (Realtek High Definition Audio(SST))
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{901876b2-57e6-4421-aca5-a87cce778cae}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek High Definition Audio(SST)) Manufacturer:
Model UID:Speakers (Realtek High Definition Audio(SST)) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{901876b2-57e6-4421-aca5-a87cce778cae}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 44.1kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 48kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 96kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 192kHz
Device #0: Speakers (Realtek High Definition Audio(SST)) Manufacturer: Model UID: Speakers (Realtek High Definition Audio(SST)) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{901876b2-57e6-4421-aca5-a87cce778cae}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: M60-C3 (Intel® Display Audio) Manufacturer: Model UID: M60-C3 (Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f3b4a4d3-9f65-41b8-ba1f-4a97f769b986}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
