Hello All, Hello Damien,
I use Audirvana and Dirac for years with success.
Dirac AU plugin works fine if I use a direct connection to my DAC (USB, Devialet Air via Wifi), specially with real time plugin configuration that appears in its window. But if I choose a direct UPNP connection also proposed by Audirvana with the same DAC, there is no AU plugin applied nor real time configuration window. No AU use possible with UPNP. Is this normal ?
I’m on Catalina and use a Devialet gear, with Dirac Live for Studio (3.x)
