Bonsoir,
Voici ce que donne le mode Debug :
Audirvana 3.5.40
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\Antoine Mazurie\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi
Preferred device: QOBUZ Model UID:PS Audio QOBUZ UID:uuid:9A5DCFE4-A182-1237-B92B-985E1B003875
Currently playing to UPnP device at 32 bits 44.1kHz
UPnP device at http://192.168.1.11:38657/description.xml
QOBUZ Manufacturer:PS Audio
Volume control: No
http-get::audio/mp4:DLNA.ORG_PN=MP4
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/ac3:
http-get::audio/x-dsf:
http-get::audio/x-wav:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 768kHz
NrTracks: 0
MediaDuration: 0:03:27
CurrentURI: http://192.168.1.16:49152/audirvana/audio_0_2.wav
CurrentURIMetadata:
dc:titleLucy In The Sky With Diamonds (Remix)</dc:title>
dc:creatorThe Beatles</dc:creator>
upnp:artistThe Beatles</upnp:artist>
upnp:albumArtURIhttp://static.qobuz.com/images/covers/mc/ab/g0tont0oqabmc_600.jpg</upnp:albumArtURI>
upnp:albumSgt. Pepper’s Lonely Hearts Club Band (Deluxe Anniversary Edition)</upnp:album>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Next
InstanceID
in
Pause
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Previous
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
CurrentPlayMode
string
NORMAL
REPEAT_ALL
REPEAT_ONE
SHUFFLE
NORMAL
RecordStorageMedium
string
NOT_IMPLEMENTED
LastChange
string
string
CurrentTrackURI
string
string
string
NOT_IMPLEMENTED
string
i4
i4
ui4
AVTransportURI
string
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
string
NextAVTransportURI
string
string
CurrentTrack
ui4
0
4294967295
1
string
string
string
string
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
string
NumberOfTracks
ui4
0
4294967295
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
ABS_COUNT
string
string
TransportStatus
string
OK
ERROR_OCCURRED
vendor-defined
TransportPlaySpeed
string
1
vendor-defined
1
0
QOBUZ
PS Audio
http://www.conversdigital.com
This model is a connected audio module which supports the UPnP/DLNA standard
DSjr DAC
CDMCM-210-001
DMR-1.50
image/png
48
48
24
/images/small.png
image/png
120
120
24
/images/large.png
image/jpeg
48
48
24
/images/small.jpg
image/jpeg
120
120
24
/images/large.jpg
/service/RenderingControl1.xml
/service/RenderingControl_control
/service/RenderingControl_event
/service/ConnectionManager1.xml
/service/ConnectionManager_control
/service/ConnectionManager_event
/service/AVTransport1.xml
/service/AVTransport_control
/service/AVTransport_event
CDM21003160474
UPnP devices found : 3
Device #0QOBUZ UID: uuid:9A5DCFE4-A182-1237-B92B-985E1B003875 Location: http://192.168.1.11:38657/description.xml
Device #1LGPC Antoine Mazurie (DESKTOP-KMGTVCI) UID: uuid:dbbe07b2-42dc-40a4-b8fe-babbefaf748d Location: http://192.168.1.16:1989/
Device #2BubbleUPnP (SM-N960F) UID: uuid:3478de90-0d36-4cc9-869b-8ea9de0b7df8 Location: http://192.168.1.17:58645/dev/3478de90-0d36-4cc9-869b-8ea9de0b7df8/desc.xml
Max. memory for audio buffers: 7466MB
Local Audio Engine:WASAPI
Local devices found : 3
Device #0: Speakers (Realtek High Definition Audio) Manufacturer: Model UID: Speakers (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4d437c42-f4b5-443a-9075-595a1cd1b9d3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Haut-parleurs (Steam Streaming Speakers) Manufacturer: Model UID: Haut-parleurs (Steam Streaming Speakers) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bfa68ad9-ae41-49f7-a9fb-e172a3a18509}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Haut-parleurs (Steam Streaming Microphone) Manufacturer: Model UID: Haut-parleurs (Steam Streaming Microphone) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5a0f8686-c8e3-45d7-9867-ca5350f6c541}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
