I updated the software for Origin (Windows 11 PC) yesterday and after being very happy with the program and all working very well it now crashes and I am unable to plate CD or hi res albums.
I recieve the message - ‘Audirvana has exited unexpectedly’
A mini dump file has been generated. Do you want to show it in Explorer?.
Has anyone else had this problem.
Terry
Audirvana Origin 2.2.3 (20203)
Windows 11 (22000) with 8GB physical RAM
Connected account of : Terry Wood
AUTO: C:\Users\terry\Music
Library database path: C:\Users\terry\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a00:23c7:f01c:f701:8f3f:1c9f:3388:438 on port 51261
Max. memory for audio buffers: 1140MB
Speakers (Realtek(R) Audio)
Model UID:INTELAUDIO\FUNC_01&VEN_10EC&DEV_0274&SUBSYS_17AA3739&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{a07cc13f-4ba1-435a-ab4d-49d8e89f1e12}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Selected device:Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model name: Intel High Definition Audio
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0274&SUBSYS_17AA3739&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{65ee5523-5869-43f3-a887-c93855f11435}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Device #0: Speakers (Realtek(R) Audio)
UPnP devices found : 2
Device #0: Denon CEOL
UID: uuid:141bfe50-4910-1634-0080-000678746d9e
Location: http://192.168.1.177:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon CEOL
Device #1: Living Room
UID: uuid:b097424a-3263-1bc6-0080-0005cdb9f152
Location: http://192.168.1.150:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz SR5014
