Hi all, I’m new to Audirvana and I have made major problems for myself. I’m hoping that someone can help me get back on track!
I downloaded and installed Audirvana on a free trial. All went well. I selected the files for my music library and got the player working.
I then found out that my music files where jumbled with several duplicates etc. So I went about re-organising them in finder. I then wanted Audirvana to re scan and make a new data base… so I deleted the database file in /Users/Library/Aplication support/Audirvana but I didn’t read the instructions properly and deleted the whole folder… I suspect this is were I went wrong!
I now get a message saying:
"Can’t find library database file at location /Library/Application Support/AudirvanaPlusDatabaseV2.sqlite
Do you want to quit now and try again later or create a new blank library file?"
I press “create new library”
and get the message:
" Damaged database file at location /Library/Application Support/AudirvanaPlusDatabaseV2.sqlite
Please restore a correct file from a backup, or delete it, and try again." with the only button ‘quit’
But there is no file in that folder.
I have tried uninstalling Audirvana using application un-installers (3 different ones) I have tried manually uninstalling removing all the associated files and rebooting and reinstalling. Nothing works I just get the same message no matter what I do!
Can anyone help me get this working again?
