Processing UI
I don’t see the vst selected
Yes I know, but I didn’t understand if the plugin works also if not editing in real time
In the above screenshot I do see that the FLUX StereoTool is enabled in the Local Processing block… The plug-ins do work using UPNP… Just configure the plug-in then play the music…
You just cannot view the plug-in’s GUI or modify the plug-in’s configuration “on the fly” when streaming to a UPNP device… If you want to modify the plug-in’s configuration you will need to stop the playback and unlock/disable exclusive access mode… Make the desired changes to the plug-in and restart playback…
If you want to test if it works you might try setting the gain down on one channel… Listen if you can tell that the one channel is muted…
FYI… The UPNP protocol is a non-realtime protocol as is TCP/IP which UPNP is stacked/layered upon… It is a network protocol issue not an Audirvana issue…
