Wondering if Qobuz connect is complatible with 3.5.50 audirvana on macos.
Qobuz works fine within the audirvana app itself, but audirvana (on macmini same network as phone) doesn’t show up in the qobuz app itself.
Is that something that is not supported with the legacy 3.5 version? is it supported on the new versions of audirvana?
No, it is just not how Qobuz Connect works. It works with compatible streamers: Qobuz Connect | Qobuz Help Center
I thought Audirvāna was acting as a streamer in this sense. Too bad that it doesn’t bc Qobuz connect is more feature rich than 3.5 (not surprising as it’s legacy software) but still too bad
Qobuz connect is more feature rich than any integration of Qobuz in another app, like Audirvana. The reason being that Qobuz decides which features it offers to integration partners through their API set. Same is true if you would upgrade to Origin or Studio.
