Qobuz app is worst than AS. But I have to keep it because:
1.AS don’t have access to the Friday Special PlayList.
2.AS don’t have AutoPlay of Qobuz suggestions.
3.AS don’t have Label Browsing - the ability to browse the catalog that Qobuz native app has.
Hello, those features are currently not available for us but we reached out to Qobuz during December and they told us we will get more capabilities with their API during 2022.
Would it be possible to separate the search results in Local and Qobuz? Currently a search result contains both and I can’t seem to figure out how to separate these
Thanks. Is it correct that when using your method Qobuz Favourites still show up? In the end I just disconnected Qobuz to be able to search only local files, not very convenient
I have both Tidal and Qobuz currently and if I click and put the line thru the mag glass next to Qobuz the results disappear and only Tidal results remain. You getting a different results?
Mark out my music up top also, its still showing favorites if you don’t
Basically mark all your mag glasses except local…… lol……sorry bout that the long way round mate
wish they stayed selected but soon it will be fixed
To prelude the obvious question that Angela Hewitt’s album is titled ‘The Art of Fugue’, the sort title is however ‘Kunst der Fuge’ and the track titles contain BWV1080 (see screenshot 4)
What I find the more annoying is that in Audirvana you cannot use more terms simultaneaously, say Beethoven+Concerto, other than using clumsy filtering
