Hi @Antoine and other forum members.
Maybe it is only me, but since update 1.10.2 all Qobuz screens are blank (except for the playlists).
An example below:
I already tried to disconnect from Qobuz and connecting again in AS, but no luck.
Anybody else has this issue too?
I am running AS on Windows 11 on a NUC i5.
Debug info:
Audirvana Studio 1.10.2 (11002)
Windows 11 (22000) with 16GB physical RAM
Connected account of : **************
r8brain to DSD256 with filter type B 7th order
AUTO: D:
Library database path: C:\AudirvanaDB\Studio\AudirvanaDatabase.sqlite
Listening on ************
HRA-Streaming: Connected as VirtualVault
Max. memory for audio buffers: 4076MB
Local Audio Engine: WASAPI
Luidsprekers (TOPPING USB DAC)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{fe3aab63-7bc8-41a6-b0e6-824ccdccc884}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Sample rate switching latency: 1s
Manufacturer: Microsoft
Model Name: Luidsprekers (TOPPING USB DAC)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fe3aab63-7bc8-41a6-b0e6-824ccdccc884}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Luidsprekers (TOPPING USB DAC) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{fe3aab63-7bc8-41a6-b0e6-824ccdccc884}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Luidsprekers (TOPPING USB DAC)
UPnP devices found : 1
Device #0JPLAY FEMTO UID: uuid:JPLAY192.168.178.192-MediaRenderer Location: http://192.168.178.192:48167/JPLAY192.168.178.192-MediaRenderer/Upnp/device.xml
