Is it possible to stream Qobuz using Audirvana on the Eunhasu platform ?
Yes, without any problem. It works as you were streaming local files.
Do you have a detailed procedure, eg. which icon does it use ?
Start MPD & DLNA service in eunhasu. In the settings you don’t need to change anything. Then go to Audirvana and select the little speaker icon in the low right corner. You’ll be able to select in the network section your sms-200. That’s it
Thanks, I’ll give it a try.
