Hello community,
I am using Audirvana 3.5 on both Windows and macOS, noticed an issue when playing back 16/44.1 local FLAC files to external DAC.
In detail:
Original track bit-depth: 16-bit
While playback from macOS, output bit-depth: 24-bit
While playback from Windows (WASAPI), output bit-depth: 24-bit
While playback from Windows (ASIO), output bit-depth: 32-bit
The DAC I’m using has PCM1792 which is a 24-bit DAC (https://www.ti.com/lit/gpn/pcm1792).
Would appreciate if anyone can help me to understand Audirvana’s behaviour with bit-depth and how can I avoid the software to upscaling the original format (checked the settings and pretty sure that I didn’t turn on any software upscaling)?
Thanks in advance
Below are the debug info I captured under each setting, hope that helps.
Debug Info - macOS
Audirvana Mac Version 3.5.41 (3571)
Registered to Edward Shen
Sync list: 2 folders
AUTO: /Users/qualia021/Music/Audio - DSD
AUTO: /Users/qualia021/Music/Audio - LPCM
Library database path: /Users/qualia021/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4000MB
TA-ZH1ES
Model UID:TA-ZH1ES:054C:0BDA
UID:AppleUSBAudioEngine:Sony Corporation:TA-ZH1ES:14600000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
ID 0x3a SENNHEISER USB 2.0 Audio Out Manufacturer:SENNHEISER
Model UID:SENNHEISER USB Audio 2.0:1377:4000 UID:AppleUSBAudioEngine:SENNHEISER :SENNHEISER USB Audio 2.0:1-284797GJ60039:1
Stream ID 0x3b 2 channels starting at 1
12 virtual formats:
12 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3a SENNHEISER USB 2.0 Audio Out Manufacturer: SENNHEISER Model UID: SENNHEISER USB Audio 2.0:1377:4000 UID: AppleUSBAudioEngine:SENNHEISER :SENNHEISER USB Audio 2.0:1-284797GJ60039:1
UPnP devices found : 1
Device #0: ID 0x0 WAVE IV UID: uuid:BO5EBO5E-F00D-F00D-FEED-C4F312BDF6BC Location: http://10.1.7.149:8091/XD/BO5EBO5E-F00D-F00D-FEED-C4F312BDF6BC.xml
Debug Info - Windows (ASIO)
Audirvana 3.5.41
AUTO: \Home-NAS\MUSIC\Classical Music
AUTO: \Home-NAS\MUSIC\OST
Library database path: D:\Application Data\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4098MB
Local Audio Engine:ASIO 2 driver version 1106
HDVD 800 ASIO Driver
Model UID:HDVD 800 ASIO Driver
Device: 2ch 32bits Integer, 8 bytes per frame 44.1kHz
HDVD 800 ASIO Driver Manufacturer:
Model UID:HDVD 800 ASIO Driver UID:HDVD 800 ASIO Driver
Device #0: HDVD 800 ASIO Driver Manufacturer: Model UID: HDVD 800 ASIO Driver UID: HDVD 800 ASIO Driver
Device #0WAVE IV UID: uuid:BO5EBO5E-F00D-F00D-FEED-C4F312BDF6BC Location: http://10.1.7.149:8091/XD/BO5EBO5E-F00D-F00D-FEED-C4F312BDF6BC.xml
Debug Info - Windows (WASAPI)
Audirvana 3.5.41
Local Audio Engine:WASAPI
Headphones (HDVD 800)
Model UID:Headphones (HDVD 800)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b726636f-d2bc-4da3-a6e8-c6f0e49e0549}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 44.1kHz
Headphones (HDVD 800) Manufacturer:
Model UID:Headphones (HDVD 800) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b726636f-d2bc-4da3-a6e8-c6f0e49e0549}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Local devices found : 4
Device #0: Speakers (Scarlett 2i2 USB) Manufacturer: Model UID: Speakers (Scarlett 2i2 USB) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e63e412c-001c-471a-b99c-1381053d430c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: DELL U2718Q (2- Intel® Display Audio) Manufacturer: Model UID: DELL U2718Q (2- Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2fbaa31-8334-46bc-a463-a6d76a85fcd3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Headphones (HDVD 800) Manufacturer: Model UID: Headphones (HDVD 800) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b726636f-d2bc-4da3-a6e8-c6f0e49e0549}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: DELL U2718Q (2- Intel® Display Audio) Manufacturer: Model UID: DELL U2718Q (2- Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cbf47f01-6a5e-47e6-93ab-50aff5488253}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
