Hi there, I’m having an issue while streaming radio. In fact, after it starts normally, stops, and there’s no way to restart. Closing and opening the app, brings back the same behaviour: working for a while and then stop.
I exclude network problem, as the same radio can play on the iphone.
Any advise? Thanks for helping out.
Hello @diesse,
Thanks for supporting!
Audirvana Studio 2.2.3 (20203)
macOS 10.15.7 with 16GB physical RAM
Connected account of : D Esse
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/xx/Music/NativeDSD/NativeDSD Music Starter Pack - NDSD017/DSD 128fs - 2ch
Manual: (OFFLINE) /Volumes/VERBATIM HD/film ago 2015/musica per damiano
Library database path: /Users/xx/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49692
Qobuz: Connected as
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
TOPPING E30
Model UID:E30:152A:8750
UID:AppleUSBAudioEngine:Topping:E30:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
Selected device:E30
Manufacturer: Topping
Model name: Topping E30
Model UID: E30:152A:8750
UID: AppleUSBAudioEngine:Topping:E30:14100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x3a
Stream ID 0x3b 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x30 Built-in Output
Model UID: AppleHDA:123
Device #1: ID 0x3a E30
UPnP devices found : 1
Device #0: ID 0x0 : Living Room
UID: uuid:6697d793-a416-1ba7-0080-0006786066e2
Location: http://192.168.178.55:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Denon
Model name: Denon AVR-X1600H
Chromecast devices found : 1
Device #0: KD-55XF8577
Model name: BRAVIA 4K GB ATV3
Can you run a test without upsampling activated?
Same behaviour. After couple of minutes it stops.
No plugin active
Phase = 66%
Qobuz: Connected as
Integer mode: ON
TOPPING E30
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 44.1kHz
Hog Mode is on
Selected device:E30
ID 0x3a
30 virtual formats:
40 physical formats
Manufacturer: Denon
Can you try to the same with your Bulid-in Output selected?
With built in audio it works, I can listen using the computer loudspeakers.
The configuration with output=Topping E30 used to work with radio without any issue.
If you use this output instead of your Topping, do you have the same behavior?
no, it works OK
Have you tried to disconnect and reconnect your Topping from your computer? Are you using the USB cable you got with your unit?
@Antoine Hi Antoine,
yes, I tried and it’s the same. I tried as well to play mp3 files stored on my laptop, as well as DSD files. The behaviour does not change.
I have noticed that while playing DSD, when the music stops playing, the E30 display goes from DSD to PCM. This does not happen when playing radio or mp3 as the display always stays PCM.
Can you try to open Audirvāna Studio using Terminal? You can find it under the Utilities folder in Application.
We recommend you to copy and paste each line one at a time and press return each time you paste a line:
cd ..
cd ..
Applications/Audirvana\ Studio.app/Contents/MacOS/Audirvana\ Studio
After you reproduce your issue, can you please send the errors you would find in Terminal?
@Antoine done. When the issue appears I do not get any message in terminal. The log below is at init.
Mac-studio:Applications xx$ Audirvana\ Studio.app/Contents/MacOS/Audirvana\ Studio
2023-03-03 15:28:07.870 Audirvana Studio[96768:19299046] UPnP: Error obtaining device description from http://192.168.178.65:9080 – error = -107
2023-03-03 15:28:08.183 Audirvana Studio[96768:19299039] UPnP: Error obtaining device description from http://192.168.178.65:9080 – error = -107
2023-03-03 15:28:08.286 Audirvana Studio[96768:19298995] Local Library Sync: Synched folders initialization: Unable to get device mount point that was /Volumes/VERBATIM HD on device /dev/disk3s1
2023-03-03 15:28:08.289 Audirvana Studio[96768:19298970] Local Library Sync: Synched folders initialization: Unable to get device mount point that was /Volumes/VERBATIM HD on device /dev/disk3s1
I upgraded macOS from Catalina to Monterey. That solved the issue!
Thanks for your support and responsiveness.
