Yes, you will find it down below. Regards.
Audirvana 3.5.43
AUTO: C:\Users\Sébastien\Music
Library database path: C:\Users\Sébastien\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4216MB
Local Audio Engine:ASIO 2 driver version 1092
Studio 192 ASIO
Model UID:Studio 192 ASIO
UID:Studio 192 ASIO
Active Sample Rate: 192kHz
Studio 192 ASIO Manufacturer:
Model UID:Studio 192 ASIO UID:Studio 192 ASIO
Multichannel: 8 channels
Channel bitmap: Ox63f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
8 ch Integer PCM 32bit little endian 44.1kHz
8 ch Integer PCM 32bit little endian 48kHz
8 ch Integer PCM 32bit little endian 88.2kHz
8 ch Integer PCM 32bit little endian 96kHz
8 ch Integer PCM 32bit little endian 176.4kHz
8 ch Integer PCM 32bit little endian 192kHz
Local devices found : 9
Device #0: AudioBox ASIO Driver Manufacturer: Model UID: AudioBox ASIO Driver UID: AudioBox ASIO Driver
Device #1: ioStation ASIO Driver Manufacturer: Model UID: ioStation ASIO Driver UID: ioStation ASIO Driver
Device #2: ASIO PreSonus FireStudio Manufacturer: Model UID: ASIO PreSonus FireStudio UID: ASIO PreSonus FireStudio
Device #3: Quantum ASIO driver Manufacturer: Model UID: Quantum ASIO driver UID: Quantum ASIO driver
Device #4: Studio 192 ASIO Manufacturer: Model UID: Studio 192 ASIO UID: Studio 192 ASIO
Device #5: Studio USB ASIO Driver Manufacturer: Model UID: Studio USB ASIO Driver UID: Studio USB ASIO Driver
Device #6: StudioLive AR ASIO Manufacturer: Model UID: StudioLive AR ASIO UID: StudioLive AR ASIO
Device #7: StudioLive Classic USB Manufacturer: Model UID: StudioLive Classic USB UID: StudioLive Classic USB
Device #8: StudioLive Series III ASIO Manufacturer: Model UID: StudioLive Series III ASIO UID: StudioLive Series III ASIO
