I had the same happen to me a few years back. Now I have a nas and several stand alone external drives. I have the same stuff on each-photographs and music. Possibly more than I need but I never want to have my only back fry again . I have not used a cloud service because there is no guarantee they are secure and they too fail.
I use SSD drives where I can. Not in the NAS, but in my singles. Thunbderbolt 3 is genuinely superfast. It copied 500Gb of music in 4 mins. I own 3 x 1 TB and 1 x 2TB, the 2 and 1 x 1tb are Samsung X5, the other two are are a 1tb Plugable and a 1tb TekQ
Sadly any Chinese-made consumer drive will be a very risky proposition.
Every single WD consumer drive I ever had has failed. All my La Cie drives also as the power supply had a known fault, and although La Cie replaced them out of warranty, this was no good for what were in fact back-up drives. More Chinese shyte.
As suggested by others an Enterprise level drive is a slight improvement.
However, again as suggested, a reliable back-up policy is the back stop.
I know the feeling.
I now use 2x4TB Porsche Design Ext HDs: 1 for my music files, the other is for backup or exact copy of HD1. And then I have a NAS to backup both HDs. I also use Backblaze to backup online, besides having OneDrive & TimeMachine running continuously You know: backup my backup? I hate loosing my files: messes my hair Take care & keep safe
As i run out of space with my 8Tb, i will follow your advise and use WD red or gold or Seagate Ironwolf pro, in a icy box to keep it simple but reliable !
Thank you for your input, i’m maybe too confident with my gear, but the chance that both drives crashes simultaneously is quite thin…
That depends on how you see it, I got RAID6’s running, simply due to the fact that I don’t want to loose data if a driver or two decides to die. And then of cause I got backups …
But yes, it does cost money, but how much does it cost to restore data (re-create), and also is it possible to restore the data?
On top of my music (don’t feel like ripping 1200 CD’s again - ever), I also have digital photos going back 18 years…
