Bonsoir,
Merci pour votre réponse, mais je n’ai aucune idée où faire les modifications. Voici le DEBUG INFO avec l’ATOLL connecté en USB. Je n’ai pas accès aux modifications…
Audirvana Mac Version 3.5.39 (3569)
macOS 10.15.6 with 16384MB RAM
Version d’essai utilisant une licence de démo
Sync list: 2 folders
AUTO: /Users/edouarddossal/Desktop/Ensemble_Correspondances_and_Sebastien_Dauce-Marc-Antoine_Charpentier_La_Descente_d_Orphee_aux_Enfer
AUTO: /Users/edouarddossal/Documents/Azureus Downloads/DAVID BOWIE Studio Discography FLAC/1969 Space Oddity (EMI Japan SHM remaster)
iTunes/Music library synchronization: last synchronized on Thu Aug 27 15:47:22 2020
Library database path: /Users/edouarddossal/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
USB Audio
Model UID:USB Audio:20B1:30BB
UID:AppleUSBAudioEngine:ATOLL:USB Audio:14300000:1
Hog Mode is on
ID 0x3a USB Audio Manufacturer:ATOLL
Model UID:USB Audio:20B1:30BB UID:AppleUSBAudioEngine:ATOLL:USB Audio:14300000:1
Stream ID 0x3b 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x30 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3a USB Audio Manufacturer: ATOLL Model UID: USB Audio:20B1:30BB UID: AppleUSBAudioEngine:ATOLL:USB Audio:14300000:1
