I’ve sent the email you requested. Here is debug info:
Audirvana Studio 1.13.3 (11303)
macOS Version 12.4 (Build 21F79) with 8GB physical RAM
Connected account of : Daniel Foster
Effects plugins ACTIVE in realtime mode with legacy macOS API
AU plugin #0: Effect - Accurate Sound HLConvolver ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Stop band attenuation 215.701dB
Phase minimum phase
AUTO: /Volumes/Music Bank/FLAC Library
Library database path: /Users/danielfoster/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 59170
Max. memory for audio buffers: 3440MB
EXASOUND AUDIO DESIGN EXASOUND
Model UID:exaSound-N1
UID:exaSoundDevice-N1
Sample rate switching latency: 2s
ID 0x3f exaSound
Manufacturer: exaSound Audio Design
Model Name: exaSound Audio Design exaSound
Model UID: exaSound-N1
UID: exaSoundDevice-N1
Stream ID 0x40 2 channels starting at 1
20 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 768kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 705.6kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 384kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 352.8kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
20 physical formats
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz
Local devices found : 4
Device #0: ID 0x33 BlackHole 2ch Manufacturer: Existential Audio Inc. Model UID: BlackHole2ch_ModelUID UID: BlackHole2ch_UID Model Name: Existential Audio Inc. BlackHole 2ch
Device #1: ID 0x4c Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
Device #2: ID 0x6e VB-Cable Manufacturer: VB Audio Model UID: com.vbaudio.vbcable.model:38114B1C-AF02-41E4-A1BC-64B91CF802F6 UID: com.vbaudio.vbcable:B6E6D02E-CD32-4C95-B60B-2FC2621CA4E0 Model Name: VB Audio VB-Cable
Device #3: ID 0x3f exaSound Manufacturer: exaSound Audio Design Model UID: exaSound-N1 UID: exaSoundDevice-N1 Model Name: exaSound Audio Design exaSound
