Following today’s update of Origin, here is the change log of the 2.2.6 version:
MacOS:
Max volume alert: when starting playback, a warning popup now asks the user if he wants to continue when the volume is set to more than 90%
Gradual volume increase: To avoid unwanted volume leap, the actual volume is increased at a maximum rate of 9dB per second to give time to the user to reduce it if needed
Media keys: give control to 3rd party apps (e.g. Teams, Zoom, Music, FaceTime) when actively used (frontmost)
Folder sync: allow to remove a synched folder that is offline
Other minor fixes
From 2.2.5:
Remote: fixed erroneous pause playback status
Other minor fixes
Windows:
VST3 plugin: workaround to correctly display plugins not compatible with high resolution screens
Additional key shortcuts for controlling playback. List shown at bottom of the appearance page in the settings
Other minor fixes
From 2.2.5:
Local folders synchronization: use new Windows 10/11 folder browser to fix OneDrive related issue
Other minor fixes
