Following today’s update of Studio, here is the change log of this 1.9.0 version:
MacOS:
NEW: Local Favorites and Playlists backup (using command in Settings, Local page)
Local library synchronization: Also synchronize audio files with corrupted metadata
Volume control: Fix +/- buttons behavior with some devices where it previously set erroneously the volume to 0
Search: remember active search sources
Navigation: going back to a view with multiple items restores the expanded (“see all”) one
Metadata editor: fix move to previous/next track
Radios and Podcsats: show all favorites, even if there are more than 20
Other minor fixes
Windows 10:
Radios and Podcasts: show all favorites, even if there are more than 20
Folders view: fix scroll for long tracks lists
Other minor fixes
