Following today’s update of Studio, here is the change log of the 2.2 version:
MacOS:
Qobuz: improved login security (oAuth 2 protocol)
Local playlists: confirmation to delete a local playlist. This confirmation popup can be asked to not be shown. Undo delete (Ctrl Z) can still be used to undo such deletion
Remote: updates needed for the upcoming remote app 4.0
Other minor fixes
Windows:
Kernel Streaming: extended compatibility for playing 24bit audio to all DACs
Kernel Streaming: further optimizations of the playback engine. Optimization level can be set in the audio settings (option in DAC input popup)
Other minor fixes
