Release notes Audirvāna Studio 1.99.20
The 1.99.20 update is now live, with the following changes:
MacOS:
  • Chromecast: fix random playback stop at end of a track.
  • Playback: clicked track is correctly the first one to play.
  • Albums and artists views: fix vertical scroll bar randomly displayed in middle of view.
  • Other minor fixes
Windows:
  • Shuffle playback: clicked track is correctly the first one to play
  • Remove unwanted white border when starting with window maximized
  • Other minor fixes
fix vertical scroll bar not resolved (macbook pro Mojave).
Remove unwanted white border when starting with window maximized" issue also exists on 1.99.20.
Does your screen has the scaling to 100%?
Can you check if the update has been properly installed? Can you also give us more information so we can reproduce the issue?
So far so good with the latest update. Turned on my Chromecast this morning and went downtown for errands. Came back two hours later and it’s still playing.
I’ll keep it running till I have to go to work this afternoon. :smiley:
I have updated to the latest beta and Audirvana keeps crashing on launch. I have forwarded the Console report via email.
I can see it, thanks for your report, we will check it out and come back to you by mail.
Yes, the scaling is 100 %, I sent a mail that consists further information.
