As of a little over half an hour ago, apparently itâs been released at last.
As I suspected, the announcement banner has been changed to reflect this.
Have fun!
Have fun!
Android & iOS Remote jetzt verfĂŒgbar
Android app installed and running
Installed the android remote app and it is working.
Awesome, I have installed and will try it out tonight when I get home from work.
Finally!..
But
âŠnot connectingâŠ
I will continue with laptop on couchâŠ
No problem
⊠Will try later again
All worked out wellâŠwindows firewall etcâŠ
All is okay now.
THANK YOU AUDIRVANAâŠ
A peine lancer et impossible de faire fonctionner la remote⊠Audirvana c est bien mis à jour mais impossible de faire fonctionner la remote. Je désinstalle, réinstalle. Rien n y fait
Je sais pas pourquoi mais je mâen doutais par avance que cela ne fonctionnerait pas
Ah câest bon. Il faut ouvrir l ancienne tĂ©lĂ©commande, ensuite allez sur le store chercher l Audirvana remote qui fait la mise Ă jour. Ăa a l air de fonctionner.
I know Iâm probably going to regret asking this because no doubt Iâm doing something stupid, but anyway I canât get the android remote app to switch from portrait to landscape.My settings on both my Samsung Galaxy phone and Galaxy tablet are always set to âauto rotateâ and every other app i have changes no problem. Anybody else the same? Iâm hoping that if I do get to view in landscape then some of the features of the old remote will be available, because for example in portrait I cannot see how to change the output device.
Edit - found how to change output device in portrait, but still canât change to landscape
It doesnât rotate here either on my Nokia running Android 10. To me itâs not an issue, because portrait is far more efficient on a phone screen
Iâve also noticed something else. When I search for an item and click on the album on which it resides it will only show the first 10 tracks on the album. Even if the album has more tracks on it.
The same thing happens if I click on an album in my favourites. It doesnât matter if itâs a local album or one on Qobuz.
New Audirvana Studio Remote, wont show more than 10 tracks of the albums⊠fix pls.
Indeed an issue.
No itâs not a deal breaker that there is no landscape, but I prefer landscape on my tablet and use it that way for Roon for example. I wonder if there is a landscape option for the IOS remote?
Itâs best to post issues with the remote here:
