Remote issue again
My remote is installed on an Xperia1V running Android 15, and it often fails to connect to the studio installed on a MacBook Pro. However, there is no problem with another Android 10 phone. I have tried all the methods, and sometimes I can connect, but as soon as I exit studio and restart it, I can’t connect. Is there any way to solve this problem? Or is this a compatibility issue with the Xperia1V?
Are the MacBook and the Xperia both on 5Ghz or is one on 2.4Ghz?
Yes, they use the same network.
Strange. You might want to consider to delete the Xperia remote, and then reinstall (if you haven’t already)
I deleted the remote, restarted the phone and reinstalled it, disabled the firewall on the computer, reset the router, deleted the data on the studio… I tried everything I could think of, but the result was the same.
Another ZenFone running Android 10 has no problem.
I think this issue is best to send to support. I don’t have a clue…
