Remote issue
Is the studio installed on the MacBook incompatible with the remote installed on the Android phone? They often fail to connect successfully. I have asked this question before, but there is no solution.
I think it should be a problem with the router. I restarted the router and it connected smoothly.
check if your router supports IGMP snooping and toggle the setting.
If IGMP snooping is on, some routers only store the info for a short period so that is why devices work for a short period of time and then drop.
