@Antoine
Using the new remote.
The same problem as the previous version persists.
Every time I change from Origin to version 3.5 or the other way around, it asks for a code.
For me - so far - it has asked for a code only in 3.5, and only on my iPad (the main remote I use). My phone works ok on both, and Origin allows both. I should add - there is no code. No six numbers on the computer screen. The iPad is just locked out.
Exactly, there are six numbers.
Every time I change from Origin to version 3.5 or the other way around, for it to work I need to type the six numbers on the cell phone’s remote control.
After entering the numbers, the operation is normal.
There is now on Audirvana preferences appearance tab to ask for a code on first connect with remote or not… might help?
