Hello There,
I have S.M.S.L SU-9 DAC that is capable of playing DSD512 files. However in WASABI mode it is recognized as capable of playing DSD256. In ASIO mode (driver installed) it shows 512 capability. However it still does not open file neither can upsample to DSD512.
yon tengo SMSL M7 Y Audirvana no reconoce posibilidades de este dac para DSD512…supongo que puede influir en el sonido…
Hola!
Make sure you use ASIO driver instead of WASAPI or Kernel and your DSD512 will be available.
