Since I purchased a new Denon AV Receiver (AVC-X4700H) I’m having problems with Audirvana.
When starting a track the sound is scrambled. Sometimes it helps to restart Audirvana or change the option upsampling to disabled or back to power of 2 and then restart Audirvana. The connection to the Denon is HDMI.
Another problem is that Audirvana switches HDMI always to Multi Channel 7.1. Thats a problem because stereo is handled in another way by the Denon receiver. I didn’t find an option to solve this. After switching to 2 channel in Audio-Midi-Setup it falls back to multi channel when starting Audirvana.
Following the debug info.
Regards
Swen
macOS 10.14.6 with 16384MB RAM
Registriert nach SB
Sync list: 3 folders
AUTO: /Users/Shared/Musik/HighRes Flac
AUTO: /Users/Shared/Musik/SA-CD RIP
AUTO: /Users/Shared/Musik/iTunes/iTunes Media/Music
Library database path: /Users/swen/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HDMI
Model UID:AppleHDA:88
UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101}
ID 0x39 HDMI Manufacturer:Apple Inc.
Model UID:AppleHDA:88 UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101}
5 available sample rates up to 96000Hz
32000
Stream ID 0x3a 2 channels starting at 1
8 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
18 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x32 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x39 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{EE11-006B-01010101}
UPnP not started
